Old 10th May 2009, 01:15 PM   #1
mrevie is offline mrevie  Australia
Default Peerless XLS 830500 Tapped Horn
I've recently acquired a Peerless XLS 830500 12" subwoofer driver and would like to use it in a tapped horn enclosure. I've run several simulations in Hornresp and have come to a set of figures that I believe I'm happy with (see attached image). The sub will be crossed at approximately 45Hz. How does the response of the horn look?
My only issue now is calculating the optimum way to fold the horn - any suggestions for this?
Old 10th May 2009, 02:22 PM   #2
And yes - I'm aware that it's going to be quite huge with the specifications used in Hornresp.
Old 10th May 2009, 02:38 PM   #3
GM is offline GM  United States
GM's Avatar
Greets!
Your driver specs are whacked, yet strangely your sim looks much better IMO using published specs, being almost identical to my default 830500 TH alignment except smaller due to yours being tuned a couple of Hz higher..........
Searching this forum will yield all the info required for a couple of ways to fold THs.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 10th May 2009, 03:01 PM   #4
GM's Avatar
Well, you can always tune it higher to reduce its size. Tune it a half octave higher and cut its bulk ~ in half.
GM
Old 10th May 2009, 03:16 PM   #5
holy crap.. the specs of my driver were all messed up. time to do some more simulations.
Old 10th May 2009, 03:28 PM   #6
Ok. Here are corrected driver specs and some minor tweaks to the horn.
The bulk doesn't bother me - I should be able to figure the folding out myself having read a few more things.
Any comments on the current model?
Old 10th May 2009, 04:29 PM   #7
GM's Avatar
Looks good to me............ Hope you post some in-mouth and in-room measurements for comparison (hint, hint ).
GM
WTB Peerless 830500 12" XLS Bent Swap Meet 0 27th February 2008 02:52 PM
Looking for a pair of Peerless XLS 830500 Miab Swap Meet 1 3rd January 2008 08:06 PM
WTB: 1 x Peerless 830500 12" XLS Bent Swap Meet 0 18th December 2007 12:50 AM
WTB: Peerless XLS 12" (830500) - just one StriatedFoot Swap Meet 3 22nd January 2007 06:05 PM
Distance to Grill using a Peerless 12" XLS (830500) askbojesen Multi-Way 6 21st April 2004 08:50 PM
Page generated in 0.09018 seconds (75.89% PHP - 24.11% MySQL) with 11 queries
