Old 8th May 2009, 01:19 PM   #1
gruni is offline gruni  Germany
Default Need enclosure advice...
Hello!
I've got some Kenford PA drivers and i'm not really sure where to put them into. i want to use the speakers as pa subwoofers, about 100hz low pass and perhaps about 35 to 40hz high pass. the main music genre is ska, so between reggae and punk. i'm planing to use 125l-boxes ( + ports) tuned to about 39hz, but i would try everything, also horns. here are the tsp:
8Ohm,
Re(Ohm)5,5,
FS(Hz)39,
Qts 0,47,
Vas(L)212,44,
B1 14,09
i know the drivers are only very low budget but i hope you can help me.
Old 12th May 2009, 10:33 AM   #2
djk is offline djk
djk's Avatar
Do a search on 'tapped horn' to get the general idea of the box.
Candidates for the Darwin Award should not read this author.
Old 14th May 2009, 01:26 PM   #3
i dont think a tapped horn is a good idea for pa...
of course i know the drivers are crap but i got them and now i want to use them...
Old 14th May 2009, 09:03 PM   #4
djk is offline djk
djk's Avatar
"i dont think a tapped horn is a good idea for pa..."
It's your right to be wrong.
A vented box should be on the order of 8 cu ft net, and tuned to about 40hz.
A TH will be larger, but have more output.
Old 15th May 2009, 12:04 AM   #5
Thawach is offline Thawach  Thailand
Thawach's Avatar
hi! djk
tapped horn is a good idea because more out put but 1/4 tapped horn,it's very long. in the past i ever saw a little. gruni if Pa horn u can go to...
http://www.speakerplans.com/
Old 15th May 2009, 01:28 AM   #6
djk is offline djk
djk's Avatar
You know, it might be possible to fold the horn to make it smaller.........nah, that probably wouldn't work.
A regular horn has to have a much larger mouth than a tapped horn, so that doesn't make any sense. Plus the T/S parameters look good for a TH, but not a regular horn.
http://www.danleysoundlabs.com/pdf/T...ec%20Sheet.PDF
Old 15th May 2009, 03:05 AM   #7
infinia is offline infinia  United States
infinia's Avatar
Default Re: Need enclosure advice...
Originally posted by gruni
Hello!
Why would you spend time and good money for custom cabs that dwarfs such a wonky driver
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 15th May 2009, 12:36 PM   #8
Default Re: Re: Need enclosure advice...
i can get wood for free, so i think its better to put them in cabs instead of throwing them into a corner...
looks like i will go for the br-cab...
Ported Enclosure Advice JakeDN Subwoofers 36 22nd April 2008 09:24 PM
fOSTEX fw168hp Enclosure advice mcmeat51 Multi-Way 7 2nd August 2007 06:52 PM
FOSTEX fw168hp Enclosure advice greenie512 Full Range 0 6th December 2006 10:06 AM
seek advice on enclosure for 18" subwofer joekjtam Subwoofers 1 10th January 2005 04:19 PM
Newbie Amp & Enclosure Advice Needed Ron Subwoofers 33 6th February 2002 09:20 PM
Page generated in 0.09657 seconds (76.43% PHP - 23.57% MySQL) with 10 queries
