Lab12 - Tapped Horn - - Page 9 - diyAudio
Old 18th July 2010, 09:24 PM   #81
Originally Posted by Brett View Post
Terry, it's only about 13" wide so bracing side to side might be a bit much - second thought, maybe not. Bracing along the length might help. Here's a pic I grabbed some time back from the big TH thread to give an idea what I mean. Stubby braces from each of the braces shown to the side walls would be how I'd try.
Is that a Lab12 driver in the picture? If yes, where can I get details of this single fold cab? Thanks.
Sam
Old 19th July 2010, 06:43 AM   #82
Brett's Avatar
Originally Posted by Samuel Jayaraj View Post
Attachment 180795
It's buried in the long TH thread, but if you PM or email through the forum, I will send you all the info I have saved.
Oh, and yes, it's a LAB12.
Old 20th July 2010, 05:21 PM   #83
Brett, I've sent you a mail through the forum. Thanks.
Sam
Old 23rd July 2010, 02:34 AM   #84
Brett's picture is of a very early Don Bunce build. HornResp was not doing tapped horns yet, and the dimensions were Don's best guess.
The L12 was good, the L23 was about 36" short, and the L34 was about 12" short for a Lab12. This design would have been a better fit
for a 3012LF. In my experience, the bracing was total overkill.
Don
Old 24th July 2010, 03:28 AM   #85
Don, I would be deeply indebted if you could show a layout of a single fold TH using the Lab12 driver where the height is 8ft (being the maximum size available for ply) and a footprint as small as possible. Alternately, I guess the height could go upto 9 1/2 feet (most ceiling height being 10' ) and I could possibly go with real wood/timber. Thanks again.
Sam
Old 24th July 2010, 10:10 PM   #86
Depending on where you live you can get sheets of wood in 10' lengths. Not full width though. Check with a local lumber yard and not the big box stores.
Old 27th July 2010, 03:45 AM   #87
Getting wood/timber in the length required is not the problem, but I don't have an optimal single fold layout of a TH using the Lab12 driver!
Sam
Old 2nd August 2010, 06:36 PM   #88
Hi Tony,
Would this modification be an improvement?
Don
Old 3rd August 2010, 09:21 AM   #89
Bump and thanks!!
Sam
Old 2nd November 2010, 08:04 PM   #90
Tweeker is offline Tweeker  United States
I cant find pn 266-943 inductor on parts express site, how many mH is it?
Be sure your foil hat has a good low impedance ground.
Tapped Horn For Car mwmkravchenko Subwoofers 365 17th November 2011 10:22 AM
help! LARGE tapped horn bubblersound Subwoofers 3 18th June 2009 05:17 PM
Tapped Horn behavior screamersusa Subwoofers 32 21st October 2008 03:31 AM
Copyright 1999-2017 diyAudio
