#21 |
I left out "a. thru j. down the left side. Here's the fix.
Don |
#22 |
Hi joqi59,
After reading through the Visaton Forum threads I tried simulating the enclosures in question, and Hornresp will give responses similar to the responses shown in the anechoic chamber graphs. As noted before, it looks like the tapped horn used as a comparison standard is sub-optimum. I'll attach a TH_v._BR comparison with a different tapped horn model. I believe this puts the tapped horn in a more appropriate light, even if the TIW 300 is not the ideal TH driver. To me the TH clearly outperforms the BR in a subwoofer application. Regards, P.S.: I hope that layertone will have more information on his LAB12 build.
Oliver |
#23 |
Last night while listening to the Fostex 168Sigma's, I felt the need for a sub to cover the most bottom end of the spectrum. I pulled out my 2 unused Lab12 drivers and began contemplating on a TH vs ELF sub. I have a intuitive notion that the TH would sound more 'natural' requiring little or no EQing, thus matching the tonal characteristics of the Fostex.
However, looking at Don's TH fold for the Lab12, a footprint of 30"x13" would have low SAF. Hence, I was wondering if I could ask here for help to increase the height and reduce the depth of the TH. Someone might have already done it and I may not know. Can someone please point out to such a fold, if it exists? Thanks,
Sam |
#24 |
use a single fold TH rather than a three fold TH. Double the height and half the footprint area.
regards Andrew T. |
#25 | ||||||
What a busy weekend! didn't get a chance to revisit this until now & wow, lots of replies, thank you all
http://www.diyaudio.com/forums/showt...12#post1586512 No damping materials used yet. Hardware, i used "Self-Tapping, Threaded inserts" I like this better than t-nuts, much more stable & doesn't pop out like T-nuts. http://www.mcmaster.com/#threaded-inserts/=1twnvs Quote:
If suitable, i will take it to a truck store & have them spray truck bed liner on it. Quote:
never experienced anything like itQuote:
Still fiddling around with it so not sure about the extension. |
#26 | |
Building a 2.1 system out of a 3/4"x4'x8' sheet |
#27 | |
The build, any specifics you would like to know? the entire 2 sheet cutout was CNC routed... By the way, any recommendations for amps? I'm currently using an under-powered Bash 300 **** correction for the link about the threaded inserts: http://www.mcmaster.com/#92105a100/=1tx8c0 |
#28 |
Hi layertone,
Thanks for the threaded insert information, have you done any comparison to the hurricane nuts (Parts Express)? When you where building the prototype 6" (W6-1139SI?) did you have a chance to do some comparison between TH and other enclosure types, measurements or listening? The Bash 500 is now on sale for $185.-- @ Parts Express, but excursion does become a problem for anything above 100W/6-Ohm into the LAB12 according to Hornresp. Probably not a big problem with music though. Regards,
Oliver |
#29 |
Depends on your needs, but for $270 this is pretty hard to beat for home theater/audio use:
EP 2500 @ B&H If you believe the ratings, it comes in at about 11.2 cents a watt, delivered. I've got one, it really does weigh in at nearly 40 pounds (same heft as my old QSC). While it is not a high-end brand name pro amp, it is still some pretty serious hardware. If you're going to be in the same room, you'll probably want a quieter fan, which is easy to do, inexpensive, and well documented on the net. Couple it with a DSP1124P, measure and dial in your response with RoomEQ Wizard, and you're set to go. |
#30 |
The BASH 500 plate amp is not flat to 20 Hz as delivered.
It can be modified to be flat though, PE even provides some basic instructions. The modifications are not too hard (I've done two amps so far), but require some disassembly, desoldering, and soldering, as well as plenty of patience. The modification requires you to change two resistors on the preamp board to change the frequency and Q of the low-pass filter and remove the factory bass boost. |
| Tapped Horn For Car | mwmkravchenko | Subwoofers | 365 | 17th November 2011 10:22 AM |
| help! LARGE tapped horn | bubblersound | Subwoofers | 3 | 18th June 2009 05:17 PM |
| Tapped Horn behavior | screamersusa | Subwoofers | 32 | 21st October 2008 03:31 AM |
| Page generated in 0.12022 seconds (87.84% PHP - 12.16% MySQL) with 11 queries |
