Lab12 - Tapped Horn -
Old 8th March 2013, 04:23 PM   #221
Shadydave is offline Shadydave  United States
Default CGS-->MKS
There are 2 systems of measurement using metric units.
The MKS sustem (Meter, kilogram, Second) and the CGS (centimeter, gram, Second).
The CGS system is slowly loosing it's following as most scientists convert to the MKS system.
However, it seems that among the electrical engineering crowd the CGS system is still quite popular.
Audio Engineering is a subset of Electrical engineering and there is still quite a bit of favor for at least the use of centimeters, if not the entire CGS system.
Hornresponse uses cm units as do most other simulation programs.
Dave
Sorry for the derailing of this thread
Old 8th March 2013, 06:55 PM   #222
kees52 is offline kees52  Netherlands
I have downloaded stepped-TH.xls sheet for folding a box, but I think it is not adequaat because it has not a constant tapered line, there is a straight piece of line, then again with some more cm2.
folding a box is I think best to cut it in parts and make the folding.
The xls sheet has just one kind of box? if I do fill in a slim box 3 times folded it prints just a part of the box on screen.
I use cm units here so it is easy.
thanks
Old 18th March 2013, 06:03 AM   #223
sippy is online now sippy  United Kingdom
Q: Could one use the 6ohm version of the Lab12 in this design?
Old 18th March 2013, 07:25 AM   #224
Sabbelbacke is offline Sabbelbacke  Germany
Is there another besides the 6 ohm?
Old 18th March 2013, 08:56 AM   #225
Ooops, my bad - posted that Q in the wrong thread, I was working on another project that had the option of 4,6 & 8ohm drive units
*confusion with my filing system, secretary has been sacked!
Old 12th May 2013, 06:38 PM   #226
Have it changed for the infinity 1260W woofer.
see sketch.
regards kees
Old 12th May 2013, 06:39 PM   #227
Oh, yes.. There is. Missed that one
Old 13th May 2013, 01:41 AM   #228
nuconz is offline nuconz  United States
see sketch.
regards kees
are the cabinet dimensions the same as those on p1 for the Lab 12?
Old 13th May 2013, 11:50 AM   #229
I did make some errors, so I have to drawn again, the box will not be much different of size.
I did see also just in hornresp that it can a lot better also, with smaller coil.
keep follow.
Old 13th May 2013, 01:11 PM   #230
keep follow.
i downloaded the .zip file into sketchup and found no dimensions, that's why i asked about the dimensions.
smaller coil? do you mean an inductor in the circuit? in series with the woofer?
Lab12 - Tapped Horn -Hide this!Advertise here!
Tapped Horn For Car mwmkravchenko Subwoofers 365 17th November 2011 10:22 AM
help! LARGE tapped horn bubblersound Subwoofers 3 18th June 2009 05:17 PM
Tapped Horn behavior screamersusa Subwoofers 32 21st October 2008 03:31 AM
