Lab12 - Tapped Horn -
Old 30th October 2012, 12:47 AM   #181
tb46 is offline tb46  United States
Default Post #179
Hi Samuel Jayaraj,
I took my drawing of Don's LAB12 TH design, and stretched it into a single fold, then I chopped it off to 96", and readjusted the parts to fit with a single taper. This should get you started.
Oliver
Old 30th October 2012, 03:53 AM   #182
Samuel Jayaraj is offline Samuel Jayaraj  India
Thank you very much Oliver for taking time off and putting in the extra effort to do the sims , drawings and sheet cuts. So this will take 2 sheets and will still require the PE Inductor. -3db may be around 23Hz but this also seems to take the max SPL up by a couple of decibels. Any comments? Thank you, once again.
Sam
Old 30th October 2012, 09:40 AM   #183
R.I.P.
Why do so many builders simulate by selecting parabolic for the expansion?
Do some of them also think that par = parallel?
regards Andrew T.
Old 30th October 2012, 01:04 PM   #184
DrDyna is offline DrDyna  United States
DrDyna's Avatar
Just to clarify, if a rectangular cross-section horn segment has two parallel straight walls and two non-parallel straight walls, then the actual area expansion will be parabolic not conical. It is therefore more accurate to specify Par rather than Con in this case.
Kind regards,
David
Old 30th October 2012, 02:36 PM   #185
Hi Samuel Jayaraj,
Post #182: "...Any comments?..."
I think you got it, and yes, it will still need the inductor. This may be a nice alternative for people looking for a different form factor. It's also an even easier build.
Oliver
Old 30th October 2012, 04:30 PM   #186
Shadydave is offline Shadydave  United States
Originally Posted by tb46 View Post
SNIP....
It also looks like the single fold has a wider passband and flatter frequency response.
Although I suspect that allot of the "clutter" and wild swings in frequency response that Hrsp. shows (in the SPL graphs) in reality get damped out either mechanically or by damping material physically added to the transmission line.
Single fold shown in bold, multiple fold shown in backround, both @ 100W (20.71 V) and 1.0 Pi
Dave
Old 30th October 2012, 05:07 PM   #187
Thanks again Oliver. Oliver and everyone else, any details of the stuffing? Thanks in advance.
Sam
Old 30th October 2012, 06:44 PM   #188
Hi again,
Generally, stuffing does not seem to be necessary, but if you use it keep it light. See: Dual 8" tapped horn = TH-SPUD for additional information.
I added a note on stuffing to the drawing.
Oliver
Old 31st October 2012, 05:46 AM   #189
Sam
Old 31st October 2012, 08:48 AM   #190
David McBean is offline David McBean  Australia
Hi DrDyna,
Just for the record - the comment of mine quoted in your post #184 is partially incorrect :-).
Please see my post Lab12 - Tapped Horn - and the subsequent further clarifying explanations to AndrewT.
Kind regards,
David
www.hornresp.net
Lab12 - Tapped Horn -Hide this!Advertise here!
Tapped Horn For Car mwmkravchenko Subwoofers 365 17th November 2011 10:22 AM
help! LARGE tapped horn bubblersound Subwoofers 3 18th June 2009 05:17 PM
Tapped Horn behavior screamersusa Subwoofers 32 21st October 2008 03:31 AM
