Lab12 - Tapped Horn -
Old 28th September 2012, 09:29 AM   #171
R.I.P.
another example where an index added to the first post would be very helpful.
regards Andrew T.
Old 28th September 2012, 11:44 AM   #172
DrDyna is offline DrDyna  United States
DrDyna's Avatar
Originally Posted by snailtrax View Post
Does anyone have a cutlist for the Lab 12 tapped horn on the first post of this thread? I have been searching for days and can not, for the life of me find it. If anyone has one could you please post it. Thanks in advance, Bill
By far the easiest way is to use this:
Cut List
I messed with it this morning and came up with what I've attached. This is for MDF or wood where you can ignore the grain direction.
Old 1st October 2012, 06:19 PM   #173
wingman is offline wingman  Denmark
Cut List
Great program.
But I may have acess to a CNC machine, it would be nice have a "cnc file" to use.
bass is music
Old 6th October 2012, 03:55 PM   #174
DrDyna's Avatar
I made these for my speaker scrapbook, just in case anyone is interested.
Old 6th October 2012, 08:34 PM   #175
Look great!
What sizes are those?
Are they just models or have you build them?
bass is music
Old 7th October 2012, 12:33 PM   #176
DrDyna's Avatar
Originally Posted by wingman View Post
Look great!
I built a pair of em, it's the same horn that's in post 1, but I used TC Sounds Epic 12s.
Old 28th October 2012, 07:47 PM   #177
averyrm is offline averyrm  United States
After much searching, I found this design as almost a perfect match for what I'm looking to do.
I'm planning on keeping this behind my couch as it will be well hidden, and good for a shelf when not cranked up too loud. With that in mind, I have some newbie questions:
1) Moving the opening so that it fires straight out (From panel C "Front" to panel F "Bottom) and having the enclosure rest on what used to be the rear wouldn't have a negative impact, correct?
2) Should I plan on mounting a plate amp (say the Bash 300) somewhere on the main enclosure, building a separate addition to house the plate amp, or getting a stand-alone amp?
I recently got into DIY speakers with the Tritrix TL mains and am adding a tritrix center and MT surrounds. This sub, although large, seems like a great value and great addition to my setup.
Thanks for the help!
Old 28th October 2012, 08:41 PM   #178
DrDyna's Avatar
It's a monster, I'm sure you'll love it. Imo, there wouldn't be a problem relocating the mouth as you've suggested. Resting on the rear puts the driver facing down. The driver I used can work like this, however I haven't checked the Lab 12 to know what it's sag % is to know if there would be any adverse effects.
Old 29th October 2012, 02:41 PM   #179
Samuel Jayaraj is offline Samuel Jayaraj  India
Can someone help me with a 2 folds plan of this TH design just for a higher WAF? Thanks.
Sam
Old 29th October 2012, 03:48 PM   #180
Thanks!
So the Epic 12 will work, how much power are you you sending to it? Would the bash 300 be too large/small?
Lab12 - Tapped Horn -Hide this!Advertise here!
Tapped Horn For Car mwmkravchenko Subwoofers 365 17th November 2011 10:22 AM
help! LARGE tapped horn bubblersound Subwoofers 3 18th June 2009 05:17 PM
Tapped Horn behavior screamersusa Subwoofers 32 21st October 2008 03:31 AM
