Lab12 - Tapped Horn -
Old 4th June 2011, 06:51 PM   #121
GM is offline GM  United States
GM's Avatar
It's somewhat misaligned, but your call as to whether it's off too much:
GM
File Type: gif CSS TRIO12 in Don Snyder's LAB12 TH.gif (11.8 KB, 936 views)
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 4th June 2011, 10:35 PM   #122
nuconz is offline nuconz  United States
GM
it'd be a one octave bass thumper. any way to "adjust" for the CSS?
CSS sells the woofer and 2 PRs for $200, which is a pretty good deal.
Old 4th June 2011, 10:58 PM   #123
m R g S r is offline m R g S r  United States
Btw I'm running this off One channel of a qsc rmx 1450. Sounds great very deep and rumbly!!
Old 5th June 2011, 04:25 PM   #124
GM's Avatar
No more so than the Lab12. Not at a glance, it really 'wants' a lower tuned alignment down around 11 Hz based on Prof. Leach's math.
Here's what I get 'blowing up' a Prof. Leach alignment to the 'close enough' same net Vb, so import it into HR to fiddle with to see how it might can be adapted:
GM
File Type: txt trio12th.txt (421 Bytes, 74 views)
Old 6th June 2011, 02:41 PM   #125
tb46 is offline tb46  United States
Hi nuconz,
When you look back at Hornresp listing in the first post, you'll see that Le is listed as 8mH. The nominal inductance for the LAB12 is 1.48mH. That means a series inductor has been added to smoothen the response. In practice that may not make much of a difference. The resistance of the inductor is added under Rg (e.g.: .1 Ohm for the supply cables, and .05 Ohm for every added mH of series inductor.)
Also, mwmkravchenko has build a nice, big FLH with the CSS TRIO12:
TRIO 12 Front loaded Horn Subwoofer
Oliver
Old 7th June 2011, 02:27 AM   #126
GM
everyone, thanks for taking the time to look at the possible "fit" for the trio 12 sw. i'm running on a linux system and don't run the cool hr sw.
Old 7th June 2011, 02:43 AM   #127
Originally Posted by tb46 View Post
Hi nuconz,
thanks for this oliver. i'm confused a bit though. the project initially identifies the driver as a CSS trio 8. but throughout the project there is reference to a 12" driver. and CSS doesn't include an 8" trio driver on their product list.
Old 7th June 2011, 03:13 AM   #128
Hi nuconz,
You are correct, the TRIO12 FLH thread meanders a bit (ok, maybe a lot), but it's well worth the time spend reading through it. CSS used to make a TRIO-8, it's shame that they don't have it anymore, was a great little speaker.
Oliver
Old 7th June 2011, 01:46 PM   #129
Hi nuconz,
ok. thanks. which was used then?
Old 7th June 2011, 02:48 PM   #130
TRIO12
Oliver
Lab12 - Tapped Horn -Hide this!Advertise here!
Tapped Horn For Car mwmkravchenko Subwoofers 365 17th November 2011 11:22 AM
help! LARGE tapped horn bubblersound Subwoofers 3 18th June 2009 06:17 PM
Tapped Horn behavior screamersusa Subwoofers 32 21st October 2008 04:31 AM
