Lab12 - Tapped Horn -
Old 12th January 2011, 11:03 PM   #111
R.I.P.
I think I have it.
The reported power input relates to the input voltage and the speaker electrical impedance at that frequency.
When the frequency hits a peak in the electrical impedance, Hornresp reports a high efficiency and when frequency does not coincide with a peak then Hornresp reports a lower efficiency.
Is that correct?
regards Andrew T.
Old 13th January 2011, 12:30 AM   #112
fb is offline fb  Australia
Bjorno,
How does the mouth of a T-TQWT compare to the port of a vented box with regards to port compression/chuffing?
Old 21st April 2011, 01:46 AM   #113
lightlinked is offline lightlinked  United States
I am building one of these and I was wondering a few things. I plan on making the outside baltic birch and I was wondering if it would be okay to use 3/4" subfloor ply for the inner baffles. I was also wondering if the dampeing material had been sorted out. I have some 1" egg crate style acoustic absorbing foam, would that be useable? And that last thing, what is everyone using as a highpass?
Old 21st April 2011, 09:32 AM   #114
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Hi all,
Maybe too delayed answers but there is a reason why I haven't posted in time :Computer problems..
Andrew T: post#111
Is that correct?
b: Yes
fbost# 112
b : If the terminating port is large enough, i.e. Port is >= Sd/3 : No chuffing is expected.
lightlinked: post# 113
b:
Which Driver/Plan are you following ?
b
Old 21st April 2011, 05:52 PM   #115
I'm using the lab12 and the 5.5 meter design by Don Snyder. So far I have the outside pieces cut, I also have the driver and all the wood, so this might be glued up by Friday. I was also thinking of using 1/2" subfloor for bracing.
Old 4th May 2011, 05:07 PM   #116
m R g S r is offline m R g S r  United States
i'm about to build this i have the perfect amount of space under my TV for it and i have the lab 12. just figuring out a cut sheet since i didn't see one posted here. i'll post up pics in the process!
Old 4th May 2011, 07:08 PM   #117
It took me two sheets of 5' x 5' x 3/4" baltic birch, 26" x 48" x 3/4" of underlay ply for the inner baffles and a chunk of 1/2" subfloor ply for bracing. If you use biscuits, the inside ones have to be layed out perfect or the side will not go on easily.
Old 5th May 2011, 02:12 AM   #118
damn that bracing looks crazy! i didn't use any bracing on mine, i just used 3/4" mdf for the whole project.
Old 5th May 2011, 02:21 AM   #119
i banged it out a lot faster than i expected...i figured i'd just go buy the wood today and get started on it..but here it is! just gotta sand and paint, and make an access panel cover!
Old 4th June 2011, 03:36 PM   #120
nuconz is offline nuconz  United States
Default Driver substitution for Eminence
any chance the CSS Trio 12 might be substituted for the Eminence Lab 12 driver?
Lab12 - Tapped Horn -Hide this!Advertise here!
Tapped Horn For Car mwmkravchenko Subwoofers 365 17th November 2011 10:22 AM
help! LARGE tapped horn bubblersound Subwoofers 3 18th June 2009 05:17 PM
Tapped Horn behavior screamersusa Subwoofers 32 21st October 2008 03:31 AM
