Lab12 - Tapped Horn - - Page 11 - diyAudio
Old 11th January 2011, 11:30 PM   #101
Originally Posted by Don Snyder View Post
Poseydon - It would work (see pic) but not nearly as well. X-max is only 8 mm for the BMS, while the LAB 12 is 12 mm.
Kepp in mind that both manufacturers use different xmax-values in the spec sheet. Eminence measures with a klippel, BMS states the geometrical value. So the "measured" xmax on the BMS is much higher (or the geometrical xmax of the LAB is much lower, works eather way)
Old 12th January 2011, 05:57 AM   #102
Thanks a lot guys!
It is obvious that the simulation with the BMS is not as good as the LAB12 and probably I am going to give up the idea. I was looking for a multi-purpose solution speaking of subwoofers /usable frequency 20-150hz/ but unfortunately there is none.
Here is what i would like to accomplish:
1. Front Stereo Channels should be a combination of fast, dynamic and detailed bass response. Probably a good idea is to build 2 subs like MTH-30 or something like it. Lower usable frequency >= 45hz.
2. Subwoofer channel speaker should go deep down to 20-25hz. Probably only one sub.
So the separation should look like this way:
20-40/45hz - subwoofer channel
45-150 - front stereo channels.
Speakers available here in Bulgaria:
Most of the BMS speakers
All Visaton Speakers
Some of the Eminence Speakers
Thanks a lot.
Greetings!
Old 12th January 2011, 10:25 AM   #103
A very large corner loaded horn could give you three octaves.
A tapped horn that is considerably smaller is unlikely to get more than two octaves.
Two or three 18inch drivers could get to three octaves, but either box volume gets very big or power goes through the roof.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 12th January 2011, 11:27 AM   #104
AndrewT, I understand your idea but unfortunately the room is not big enough.
I have two free corners in which I can place 250*40*40 cm box.
If I use a single folded design /tapped horn?/ with 12" speaker probably I will get down to 25hz?
Probably my questions is not placed in the correct thread...Sorry for that!
Old 12th January 2011, 12:32 PM   #105
if the 12inch is the eminence driver and you build a tapped horn then you are in the correct thread.
If you set your TH to achieve 25Hz then expect ~100Hz as a reasonable maximum frequency.
regards Andrew T.
Old 12th January 2011, 01:13 PM   #106
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
...I was looking for a multi-purpose solution speaking of subwoofers /usable frequency 20-150hz/ but unfortunately there is none...Here is what i would like to accomplish:
2. Subwoofer channel speaker should go deep down to 20-25hz. Probably only one sub...So the separation should look like this way:..20-40/45hz - subwoofer channel...45-150 - front stereo channels...Speakers available here in Bulgaria:..Most of the BMS speakers..!
Hi, If you consider the MTH-30 using the BMS-12S330, you're leaving, IMO, Hi-Fi SQ for live PA Mid sound colorations/artifacts. See a simulated example using this driver in a system capable of THX levels and superior SQ:
b
Old 12th January 2011, 01:30 PM   #107
Hi B,
I'm confused.
Which column of reports belong to which arrangement?
I see Tapped Horn and T-TQWT and sealed box.
regards Andrew T.
Old 12th January 2011, 01:38 PM   #108
Originally Posted by AndrewT View Post
Hi B,
which column of reports belong to which arrangement?
Hi Andrew,
The first vertical column concerns a T-TQWT-sub and the second to a closed mid-bass box: suggested to be a part of a main speaker system.
b
Old 12th January 2011, 02:03 PM   #109
Then,
why does the TQ show 290W (effic~0.3%) for 30.98V input,
but the sealed shows 9W (effic~2%) for 30.98V input?
regards Andrew T.
Old 12th January 2011, 04:06 PM   #110
Then,
The efficiency depends on the different specific system load impedance given as a function of the frequency in use : See the picture for more comparisons.
b
Tapped Horn For Car mwmkravchenko Subwoofers 365 17th November 2011 10:22 AM
help! LARGE tapped horn bubblersound Subwoofers 3 18th June 2009 05:17 PM
Tapped Horn behavior screamersusa Subwoofers 32 21st October 2008 03:31 AM
Copyright 1999-2017 diyAudio
