Lets say we have a port of 100mm length and the air in it is moving 10mm p/p. All is working as it should. Now some teenager comes along and cranks up the volume a bit and we have the port air moving 300mm p/p, several times the length of the port.
The question is, does the port air mass behave in exactly the same way in both instances as far as box tuning is concerned, seeing that the air within the port at one moment completely leaves the port at another moment to be replaced by other air?
Best-ever T/S parameter spreadsheet. http://www.diyaudio.com/forums/multi...tml#post353269 |
#2 |
once you exceed a certain port velocity the port compresses and the enclosure then acts as a very leaky sealed enclosure.
#3 |
Define exactly the same - it obviously isn't if the excursion is 30x as great. As far as T/S theory goes, the port acts like a rigid piston. In real life, there is a whole lot more going on.
Say your port is tuned to 40 Hz - then it moves 300mm in 1/4 cycle so that is 160*.300 = 53.3 meters/sec - this is well beyond the realm of port compression, which is classically expected to start being significant at around 1/2-1/3 this velocity. What's the motivation for the question, or was it just a thought experiment?
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#4 |
Just a thought experiments. I pulled the numbers out of my own port.
#5 | |
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo My setup: http://www.diyaudio.com/forums/multi...tang-band.html
#6 | |
ROFL Age Stereotypes! I blew some big speakers in my 20's, but not in my teens, LOL
You can call me Mad Professor, building crazy experiments in my Electronics Workshop |
#7 |
In practice, at high levels the ports start to 'chuff', the tuning frequency shifts upwards, and then it starts acting like the leaky box.
Candidates for the Darwin Award should not read this author. |
#8 |
I agree there - I messed around with a small sub (before blowing it with several times more power than it's made for - courtesy of dad's PA amp) and, even just by listening, you can hear the port tuning change as volume changes. This, however only happens past a certain point, which must be the dist. moved by air >/= length of port.
Which means we need longer ports for higher volumes...
#9 |
"Which means we need longer ports for higher volumes..."
More port area is needed (which means they are longer). At some point a PR becomes needed.
| port length | jwhit67 | Multi-Way | 1 | 6th March 2008 12:29 PM |
| Help with port length please | Bobhof | Multi-Way | 3 | 2nd May 2006 06:32 PM |
| port length | busterno1 | Multi-Way | 5 | 27th October 2003 08:05 PM |
| port length | dave k | Multi-Way | 13 | 13th July 2003 02:32 PM |
| Page generated in 0.09770 seconds (77.81% PHP - 22.19% MySQL) with 10 queries |
