Old 29th April 2009, 07:02 PM   #1
cm2677 is offline cm2677  United States
Default Types of Subwoofers
Hi, I am wanting to build a subwoofer of my own. Can someone tell me what the difference is between a subwoofer that is used in a car vs. one that is used in a HT system? I have been to Parts-Express and Rythmik Audio and am still have no idea what the difference is.
Old 29th April 2009, 07:16 PM   #2
Did it Himself
richie00boy's Avatar
Generally a car sub will not need to go as deep as the cars cabin will provide some natural boost to the output at lower frequencies. Also a car sub will usually need to be smaller than one for a home, so the drivers are designed to suit that application which requires more power.
If you choose wisely you can use a driver marketed for cars, in the home.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 29th April 2009, 10:13 PM   #3
As a newbie to this board and still quite ignorant about some things Hi-Fi, I understand the difference this way. SubWoofers are more about Home Theatre technically as they focus on frequeicies below 100hz and are usually crossed over lower than that. Sub frequencies are not as much about music as they are about reproducing large sounds found in movies. A 6.5" subwoofer will go lower and need to be crossed over lower than a 15" woofer which can sometimes be crossed over as high as 300hz or higher.
A subwoofer can be located away from the mains if it is crossed over low enough. It doesn't need to be tuned as low though for music. Most car stuff is about SPL and small enclosures.
Old 30th April 2009, 12:00 AM   #4
Default subwoofer description,applications
Hi there: For a more complete description try www.Wikipedia.com especially paragraph 3 applications. .... regards, Michael
Old 30th April 2009, 01:07 AM   #5
Thawach is offline Thawach  Thailand
Thawach's Avatar
Be careful some parameter of car drivers are bad.
i don't think like this, i see a lot from HT with deep bass.
Old 30th April 2009, 02:01 PM   #6
OK, thanks for the info.
Also, what are your thougths on using a Servo Subwoofer?
Old 30th April 2009, 02:03 PM   #7
tinitus is offline tinitus  Europe
Cant go wrong with Rythmik servo subs
Old 30th April 2009, 04:50 PM   #8
chris661's Avatar
Servo as in ServoDrive, or the ones by rhythmik audio??
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 30th April 2009, 05:13 PM   #9
The ones from rhythmik.
Old 2nd May 2009, 05:06 PM   #10
chris661's Avatar
HT subs are designed for the low rumbly stuff in films
Music subs are designed to be more musical, with tuneful bass,
Car subs are designed to use to gain of a car's cabin to its advanatge.
9 times out of 10, a car sub will be a sealed box, with a long-throw driver and a huge amp to power it with.
OS-CON types Glenn2 Digital Source 2 13th May 2007 12:07 PM
For you EE types, please help JMB Digital Source 5 1st July 2005 07:27 PM
For you EE types, help please? JMB Multi-Way 0 30th June 2005 10:13 PM
Can't see some types of images LukasLouw Forum Problems 19 20th November 2004 03:31 PM
Speaker Types.... lemondog Subwoofers 13 4th March 2002 04:18 PM
Page generated in 0.08592 seconds (85.85% PHP - 14.15% MySQL) with 10 queries
