Old 21st April 2009, 09:47 AM   #1
AdamZuf is offline AdamZuf  United Kingdom
Send a message via ICQ to AdamZuf
Question Push-pull LF driver for up to 250Hz
Hello guys,
I want to have a 2 driver, top quality, push-pull floorstanding cabinet that can be crossed as high as ~250-300Hz, 2nd order at least.
Should extend to <35Hz at least -3dB.
The box can be as large as 110 liters (55 per driver).
I can have up to 12" drivers (rotated, for a slim box), but less diameter would be nice and open design possibilities, however not crucial.
Don't want to go more then $200 per driver.
Sensitivity is better then power handling, as always.
Should do well with all types of music except classical. I prefer a fast and very dynamic sound then soft and laid-back.
It's not intended for HT.
My living room is medium size.
The drivers will be at 90cm height, if that's of any concern.
Any good suggestions?
Adam
Push-Pull driver stage? alexmoose Tubes / Valves 12 18th September 2006 11:38 PM
modify parallel push-pull EL84 to single push-pull chungtat Tubes / Valves 12 3rd November 2005 11:25 PM
Double push-pull versus single push-pull jraraujo Tubes / Valves 19 19th October 2002 12:23 AM
Push Pull driver newbie question Diogo Solid State 9 10th August 2002 06:13 PM
In push/pull woofer mounting, Why Vas will be half that of single driver? haggy Multi-Way 7 10th December 2001 02:29 AM
Page generated in 0.07364 seconds (64.50% PHP - 35.50% MySQL) with 10 queries
