Old 18th April 2009, 05:04 PM   #1
Default Patrick Snyder's Bass Reflex Equalizer
Does anyone have a copy of Patrick Snyder's (SpeakerLab fame) Bass Reflex Equalizer paper, where it shows the schematic of the equalizer?
TIA
bwhitejr
Old 21st April 2009, 03:38 AM   #2
djk is offline djk
djk's Avatar
It's just a 2nd order filter with a Q=2 and an input buffer.
Candidates for the Darwin Award should not read this author.
Old 21st April 2009, 10:55 AM   #3
Thanks for the response. Would anyone happen to have the schematic or the paper itself? I would appreciate it very much.
bwhitejr
Old 21st April 2009, 12:25 PM   #4
djk is offline djk
djk's Avatar
http://sound.westhost.com/software/esp-lr13.exe
Check 12dB, check High Pass, enter cap value, enter frequency.
This gives the resistor value for a Q=0.5 (LR)
For a Q=2 (6dB boost):
Take resistor value times 4 for the resistor going to ground.
Take the resistor value and divide by 4 for the feedback resistor.
Example:
32hz
100nF
49.74K (Q=0.5)
*4=198.96K (Q=2)
/4=12.435K (Q=2)
For the higher value resistor, pick the next highest standard value.
For the lower value resistor, pick the next lowest standard value.
The square-root of the product of the higher and lower value resistors should be equal to the original Q=0.5 calculated value.
Old 21st April 2009, 04:58 PM   #5
freddi is offline freddi  United States
freddi's Avatar
I don't have the orginal paper anymore (or its buried) here's the scheme from Weems - not sure how well the adjustable feature works - seems like DJK commented
heres the page with parts list
Old 22nd April 2009, 12:03 AM   #6
Freddi,
Thank you very much. That is exactly what I needed. I have the paper somewhere, but couldn't find it. Every now and then the old stuff is valuable.
Again many thanks.
bwhitejr
Old 30th April 2009, 07:39 AM   #7
dangus is offline dangus  Canada
I sort of remember an article in Audio magazine with a similar circuit. Probably the same as:
"W. M. Leach, Jr., "A Generalized Active Equalizer for Closed-Box Loudspeaker Systems," Journal of the Audio Engineering Society, vol. 38, no. 3, March 1990."
Here's a sub project with a similar equalizer, including layouts:
http://home20.inet.tele.dk/audio/mini-sub/mini-sub.htm
css bass reflex paulfk Full Range 7 8th March 2009 11:25 AM
New Here - New project: TL or Bass Reflex? gymwear5 Full Range 2 2nd January 2009 07:52 AM
bass reflex for Ariel ME2 GAK Multi-Way 2 22nd December 2003 11:39 PM
Bass Reflex Guss Multi-Way 1 15th December 2003 02:33 AM
bass reflex? GAK Multi-Way 2 23rd October 2001 03:04 AM
Page generated in 0.09009 seconds (75.94% PHP - 24.06% MySQL) with 10 queries
