Old 13th April 2009, 07:54 AM   #1
Default My latest build SS 23W
Here is my latest build - just finished a Scan-Speak 23W subwoofer to match with Ellis 1801b speakers.
I'm using Stochino amps to drive the 1801s, an Aussieamplifier 200W amp to drive the 23W and a Borbely All-FET crossover to split at 100Hz
Here is the first photo of the build - I used 25mm MDF sandwiched to 12mm fiddleback stringybark - finished with 3 coats of danish oil
Old 13th April 2009, 07:56 AM   #2
Here is the second build photo
Old 13th April 2009, 07:58 AM   #3
And another
Old 13th April 2009, 07:59 AM   #4
Shot of the top - hard to see the real 3D effect of the fiddleback
Old 13th April 2009, 08:01 AM   #5
And the final shot of it in the room
Old 14th April 2009, 11:31 AM   #6
Amazing work! Listening impressions?
Old 14th April 2009, 11:50 AM   #7
I've just made a minor adjustment to the crossover to increase gain in the LP buffer stage from unity to 6dB, as the 23W seems very inefficient (if you're after high SPLs this isn't the driver). Now I have the balance just right between the 1801s and the sub. Integration is very good and the sub does go deep. Bass is nice and tight and the combination of the 2 is sweet - they really do go very nicely together (if anything I think the sub improves the 1801s - lets the Seas concentrate on its strong point). I am very happy with the result.
My latest Andrewbee Full Range 14 7th December 2005 03:14 AM
build my first full ranger,let's build another one:a small fullrange high end pc-spea then_dude Full Range 2 30th November 2005 07:54 AM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 09:52 AM
My Latest ir Chip Amps 9 12th February 2004 04:17 PM
pix of my latest jsalk Multi-Way 19 4th July 2003 05:57 AM
Page generated in 0.08523 seconds (73.84% PHP - 26.16% MySQL) with 11 queries
