Need help seting up my SWR-1222D Need help seting up my SWR-1222D - diyAudio
Old 10th April 2009, 05:48 PM   #1
blair99 is offline blair99  Canada
Default Need help seting up my SWR-1222D
<a href="http://s626.photobucket.com/albums/tt341/9blair99/?action=view&current=subsetup.jpg" target="_blank"><img src="http://i626.photobucket.com/albums/tt341/9blair99/subsetup.jpg" border="0" alt="sub set up"></a>
I have a SWR-1222D and i was wounder what is the best way to set up my sub. ( Plug in config)
I have a iDA-X100 deck and a
PHOENIX GOLD RSd 1200.1 1200-Watt Sub Woofer.
So if some one could tell my what example to use from the Manuel that would help me out a lot thanks.
Old 10th April 2009, 06:59 PM   #2
littlemike is offline littlemike  United States
Your sub amp is not 1-ohm stable, so you have to use the diagram in example 1. This wires the coils in series, resulting in a 4 ohm load.
Your amp will deliver more power than the driver is rated for (675 vs 500) with a 4 ohm load, and will run cooler.
Old 10th April 2009, 07:20 PM   #3
example one is the best ok thanks so much. I have when threw 3 subs so far.
Need help seting up my SWR-1222DHide this!Advertise here!
MarantZ CD65 seting-up? ZuMbAiU Digital Source 2 12th March 2006 03:58 PM
Copyright ©1999-2017 diyAudio
