Hi guys,
Just wondering if it is better to have ports mounted on the bottom or the rear of the enclosure? The driver itself is down-firing, and the enclosure is on a platform so that whole "carpet" thing isn't an issue. Cheers. |
#2 |
Hi!
Make sure the speaker doesn't get out of phase with the bassreflex tube! I dunno how to do that really. Hope this tip helps! Kindest Reegards, Wolfgang |
#3 |
Use winISD to sort out the whole size and diameter of the port
Other than that - down is probably best, as speakers (especially rear ported ones) tend to not like being close to a wall.
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo My setup: http://www.diyaudio.com/forums/multi...tang-band.html
#4 | |
#5 |
I have built sealed and ported but always went back to sealed .
From what I read , any driver to be used for down firing must not sag too much , I think 10% max . ports dont care too much about location but is best on the speaker face . As the other letter stated any port noise will be absorbed by the ground (which is great ) |
#6 | |
#7 | |
And ports do care about location - even front firing ports can sound boomy when the speaker is near the wall And why try to cancel the port noises, when you could simply round off the edge of the port, which takes out noises. Down firing port would care less about location than rear, but it would still matter.
#8 |
[QUOTE]Originally posted by Brett
[B]There is no reason why placement on the baffle is universally best Here is some science.. at 20 hertz the wavelength is 55 feet so location wont matter , but at 100 hz the wavelength is 11 feet , so if the port is 3 feet away from the cone , its 1/4 wavelength away and so the cone and the port will be partially out of phase and cancell a bit . You definitelly dont want the port 5 feet away from the cone (in like a sonotube) |
#9 |
that's exactly what I've been trying to tell you. If the tube gets out of phase with the driver, you will end up with even less bass than a sealed. If the driver and the tube are both on the front, it might be tricky to get them to play in phase. If they are on different sides of the speaker, that problem doesn't exist.
#10 | |
[QUOTE]Originally posted by bottomfeeder
[B] Quote:
I still stand by my statement that front is not universally best as you stated. To give an example, the last ported sub I built had the driver on the baffle at the very bottom, and the port was on the bottom only a short distance away, so phase difference was minor. I can always find an extreme example to make a point, but I understand physics well enough to not make the mistake of ports several feet away. |
| side/ rear firing speakers Good/Bad? | mcmahon48 | Multi-Way | 1 | 6th February 2009 12:28 PM |
| what is the impact of having a rear firing port | peteS | Multi-Way | 8 | 4th March 2006 03:43 AM |
| Rear firing Seas 27 TDFC | LNeilB2 | Multi-Way | 9 | 9th August 2005 01:35 PM |
| Down firing ports | jethari | Multi-Way | 1 | 19th November 2002 06:30 PM |
| rear firing tweeter - why? | bbaker6212 | Multi-Way | 5 | 25th September 2002 12:50 PM |
| Page generated in 0.10412 seconds (84.93% PHP - 15.07% MySQL) with 10 queries |
