Old 16th April 2009, 01:10 PM   #41
MaVo is offline MaVo  Germany
Originally posted by AndrewT
the benefit of the horn is that it can approach 50% efficiency in the passband.
I don't think there is any bandpass or vented or sealed enclosure that can achieve that.
Maybe you can point me to a paper that shows how these "boxes" can approach 50% efficiency in the passband.
Sorry, i think i wasnt clear enough on this. If you take a tapped horn and make the mouth very small, lets say 1-2 times the membrane area, then its behaviour is close to a BP6. If you make the mouth big, the effects of horn loading get more pronounced. You still need to have a full sized mouth to get to 50% efficiency with a tapped horn, just like with every other horn. The advantage is a flat response with small mouth size. This gives you more options to tailor a subwoofer to your needs, but it doesnt make it more powerfull than the other enclosure types. Output per volume for a given driver type should be the same no matter what enclosure type you choose.
Old 16th April 2009, 01:20 PM   #42
Is the small volume of the TH also at the expense of efficiency?
this seems to be confirming my question/answer.
regards Andrew T.
Old 16th April 2009, 04:54 PM   #43
GM is offline GM  United States
GM's Avatar
Correctomundo, no matter the internal configuration, net box Vb sets the max acoustic gain over whatever BW it's configured for.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 16th April 2009, 06:55 PM   #44
iand is offline iand  United Kingdom
True if the tapped horn is exponential (or hypex) to maximise efficiency near cutoff -- if it's conical (like most TH) then there's wasted volume near the throat and the acoustic impedance (which means efficiency) drops near cutoff.
In other words a full-size hypex FLH with 50% efficiency (same mouth size) is smaller and has flatter response than a conical TH with the same cutoff and 50% efficiency -- which is what Tom said, if you've got room for a full-size FLH (which few have for bass) then build one, if you haven't then build a tapped horn.
Ian
Old 17th April 2009, 11:05 AM   #45
JLH is offline JLH  United States
JLH's Avatar
Originally posted by Bent
@JLH - If "you could hear the mallet hit the drum before the bass pulse" is that group delay or is that the way a drum actually sounds - I guess you probably should hear the mallet hit first ..?
Yes, you should be able to hear the mallet strike on good clean recordings. There should not be any distinct delay between the mallet strike and the bass pulse. It should just be on the leading edge of the bass pulse from the drum.
Rgs, JLH
Double Driver Tapped Horn MaVo Subwoofers 28 23rd January 2009 05:38 PM
how to calculate resonance freq in H-baffle bvan Subwoofers 5 14th January 2009 10:52 PM
Page generated in 0.08530 seconds (73.98% PHP - 26.02% MySQL) with 11 queries
