Old 1st April 2009, 02:26 PM   #1
Default I'm looking for a small plate amp.
Hello,
this is actually the first my-own-started thread in this forum.
I hope this category is the right place for this kind of question.
Ifm looking for a plate amp for my small desktop audio system. There are no plate amps available in Japanese market because subwoofers are not popular among DIY builders.
Could anyone let me know some appropriate units and Internet shops hopefully available from Japan? I would like a good-enough one (but not the high-end). 30 W / 8 ohm will be sufficient. Crossover: 100 c 150 Hz.
Please check the attached picture for the system overview or gWWWh for further details.
Matsumoto
Old 1st April 2009, 03:26 PM   #2
jbell is offline jbell  United States
Here's a thought for you, that you may not have considered. Assuming you have a pc with a good (400watt or so) power supply, you have all the clean 12v you need for car stereo components (like subwoofer crossovers, or amplifiers)
You are also closer to hong kong, and cheap electronics than most of us... for the 2x15 class d tripath boards, etc.. (A 2x15 would power your 4 little drivers pretty well at 4ohm per channel.)
You don't have to go plate amp. My assumption is that your PC case has plenty of space inside to put whatever amplifier, crossover, etc.. you need inside for a nice clean install.
Old 1st April 2009, 10:27 PM   #3
Thank you, jbell san !
I've never thought of Car audio area.
It might be a possibility. Subwoofers are quite popular in this area also in Japan. I'll check it.
I have a spare PC case with a 12 V power unitA so anything can be stuffed in it.
Matsumoto
Plate Current VS Plate Voltage Graphs Captn Dave Tubes / Valves 2 13th February 2009 08:57 PM
ECC83 - Long Plate vs Short Plate poynton Tubes / Valves 16 17th February 2008 07:42 AM
2a3, single plate-double plate? tenderland Tubes / Valves 5 30th October 2005 09:03 AM
Subwoofer Plate Amplifier Base Plate supplier? jwells777 Parts 1 11th May 2003 07:40 AM
Page generated in 0.06814 seconds (74.89% PHP - 25.11% MySQL) with 11 queries
