Hi everybody i'm doctor nik. (sorry just saw an episode of simpsons
I have 24 10" peerless xls 830452 drivers, My question is really simple, what would you do with them? I myself had two different thinks in my mind, First idea is 6 basrefleks kabinets with 4 units in, a volume of 180liters and tuned at 22 hz second idea is bying 24 400grams pasive radiators, but i thought that it might be a little too expensive I will be using the subwoofers for both music and movies. i hope YOU have some great ideas or comments about my own, thanks for sharing your wisdom |
#2 |
How about building 3 with 4 isobaric pairs and a 18" passive radiator in each box.
Or follow your orginal plan with 6 18" passive radiators instead of 24 10" passives Alternative 3 are a pair of sealed towers with 12 drivers in each. 4 paralleded groups with 3 series wired woofers should ~6ohm load and enough powerhandling to do some serious eq Alternative 4 are 4 sealed towers with 6 drivers in each 3 pairs with series wired woofers ran in paralell should~5,7 ohm load and still leave enough powerhandling for some eq |
#3 |
Hello,
Sounds like a dipole subwoofer project. Make it as line array 12 per side. Even more interesting would be second order gradient subwoofer project. 6+6 per side. - Elias |
#4 |
Do you want to use them all, or do you want to sell some of them?
I guess the first question is: "what does your space look like?" I think two great dodecahedrons would look pretty cool. If you got 24 PR's you could make 4 great dodecahedrons, each half PR's and half active drivers. You could make an array of 16 drivers that you could then plug into a wall outlet and tear your home apart with.... You could build them into wall enclosures like a guy named Tom Perazella did with 8 DVC12's, to great effect.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#5 |
If you have a rectangular room, I would do a dual bass array (dba) subwoofer and dipole woofers, and then sell the rest.
http://www.avsforum.com/avs-vb/showthread.php?t=837744
double complete rainbow all the way!! |
#6 | ||
the room is on the second floor and therefore have tilted walls. 7,5 X 8 meters The think the wall sub could be cool, but i'm want the solution to be a little more flexibel. and would prefer if it didn't have to big a footprint edit- And if less than the 24 units can do it, i'll sell a couple. |
#7 |
Wow, 24 XLS10 Woofers!?
I would consider building multiple sub woofers and distribute them around the listening room. Why? In any room, that is below the size of a large hall, low frequencies emitted from one source, will excite room modes, i.e. standing waves. Above a certain frequency, the number of modes will be so many as to give a statistically average, i.e. diffusion. If you have more than one low frequency source, you will have, at least in theory, a correspondingly greater number of low frequency room modes, giving a more averaged room response. This is why I'm planning to build stereo- subs rather than just one. |
#8 |
Would it be an idea to go iso-brarik here???
I haven't read much on these drivers, so I could be wrong. By the way - how did you manage to get that many of those drivers???
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo My setup: http://www.diyaudio.com/forums/multi...tang-band.html
#9 | |
Personally I'd put them all in one floor to ceiling box in the corner, loaded push - push. I'd run them sealed 30Hz down and cross to my labhorns 30Hz up... Infrabass baby Rob. |
#10 | |
but why a sealed box, By my knowlege, there are clearly designed for vented/passive boxes |
| My new subs. | Phil Olson | Subwoofers | 5 | 26th April 2008 06:00 PM |
| Looking at more subs. | skooter | Car Audio | 3 | 2nd December 2007 06:10 PM |
| SUBs with these:? let us know... | kyselym | Subwoofers | 0 | 11th January 2007 05:33 PM |
| Convert floor standers to subs with Tang Band 8" subs? | prerunnerv6 | Subwoofers | 3 | 26th February 2006 12:44 AM |
| 2 subs one box/2 subs 2 boxes | vetkilr | Subwoofers | 5 | 22nd February 2006 09:27 PM |
| Page generated in 0.11532 seconds (85.70% PHP - 14.30% MySQL) with 11 queries |
