Old 25th March 2009, 06:30 AM   #11
The curve looks great GM but some of the spec #'s look odd to me. I must first apologize for not being familiar with hornresp. I tried to download it twice, but it will not run on my computer. I'm OK with the exponential flare, but need to know the throat and mouth area. As well as the lenght. Thank you. I like your identity pic. I have the book that photo came from. I have read the book, but have yet to apply or understand it's teachings. Thank you for your time.
Old 25th March 2009, 07:59 AM   #12
Hi SIRDRINKSALLOT,
Have you tried running Hornresp Version 20.00 or later? The program was converted from 16-bit to 32-bit operation at Version 20.00, which might make a difference if you had been downloading an earlier version.
Kind regards,
David
www.hornresp.net.ms
Old 25th March 2009, 05:35 PM   #13
GM is offline GM  United States
GM's Avatar
You're welcome!
Actually, since HR's alignment using its design Wizard ~ matched my calcs I just posted its results.
You'll have to be more specific about the odd specs. All I did was input yours plus assumed a 6.8 ohm Re since I found out it's a dual 4 ohm VC driver, ergo a nominal 8 ohm driver if wired it series. BL, etc. is calc'd by HR based on the T/S specs you listed.
Ideally you need to figure out why you can't get HR to run in case you want to make any changes or just try to find a different alignment.
throat = 2226.2 cm^2
mouth = 99999.99 cm^2
length = 752.66 cm
rear chamber = 635.36 L net
front chamber = 41823.29 cm^3 net
Obviously, at these sizes, rounding off numbers is not going to be audible.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 25th March 2009, 08:21 PM   #14
Default 11 foot horn
Hi there: An alternate location would be to place the horn in an attic space of a pitched roof, an eleven foot horn opening in the ceiling would eliminate the need for hand rails around an eleven foot opening in the floor. How about two of these horns in the ceiling for some real bass. .... regards, Michael
Old 26th March 2009, 04:19 AM   #15
Default Tapped Horn
Hi There: On a serious note, since you have space available, you may take a look at the photos and information on Tapped Horns found on William Cowans home page, and in another post some one else reported on building this type of horn into the floor joists in a crawl space below his listening room floor, with the horn mouth exiting upward. ...regards, Michael
Old 27th March 2009, 07:15 AM   #16
I'll be sure to check out the Cowans page before I go to much further. Whatever I end up doing I'll be sure to take plenty of pics along the way. I will certainly post them here. Thank you to all who contributed.
LM3875 bass amp oris horns Diy martin Chip Amps 0 4th November 2006 07:18 PM
what do those compromised small bass horns actually sound like? paulspencer Subwoofers 10 27th October 2005 03:21 PM
Front loaded bass horns for sale Jimmy D. Swap Meet 3 6th January 2005 05:28 PM
Bass Horns...... How come so small? Mikett Multi-Way 10 14th January 2004 01:19 PM
Bass Horns? Chris_SWE Multi-Way 7 7th January 2002 03:58 AM
Page generated in 0.08830 seconds (75.94% PHP - 24.06% MySQL) with 11 queries
