Old 27th March 2009, 10:26 PM   #21
chris661's Avatar
It's an idea, but I've seen the size of subs which use horns....
maybe when I get my own house...
And I've never really done speaker building on this scale before, so I think a simple, sealed box would be better, as there's less to go wrong...
101Litres for the box vs the 42L box I'm going to use....
In a small room.
Not really what I'm looking for, but a good idea nonetheless.
Thanks for the input, and for looking
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 15th April 2009, 08:56 PM   #22
chris661's Avatar
Ok - subwoofer all built - even mum is pleased
I decided on a cube shape
drivers in push/push configuration, with one driver facing into the cabinet, and one facing out
This removed second harmonic distortion.
Then I built the thing
I was forced to use chipboard, because we have loads of it, and it matches the furnature in my room...
made 2 black covers (MDF + speaker cloth)
stuck those on with sticky pads
I have only braced it vertically so far
Plan to make some horizontal braces, weather permitting...
I also "borrowed" dad's 17 year old PA amp - I know it's not ideal, but it was that or a 7W/channel amp I took out of some rubbish 2.0 speakers.
Pictures attatched...
Old 15th April 2009, 08:57 PM   #23
chris661's Avatar
Default The review
and with the covers on, in my room
Well, it's not the loudest I've heard, but it's (easily) the lowest (not including cinemas)
The bass is fast, low, and generally chunky sounding - which is good
The thing is that i spent £32 on drivers
£5 on LT circuit components
£5 on MDF + speaker cloth
The rest I already had (eg amp)
so - my £42 project, which created "the best-sounding reasonable-sized sub I've ever heard" - according to dad, who is (past 40) positively ancient, and must have heard some systems in "his time".
I will draw up the design, and post that, with pics of bracing etc, when I find the time...
Old 15th April 2009, 09:29 PM   #24
Did it Himself
richie00boy's Avatar
Glad it worked out How are you doing the crossover and what speakers are you mating it up with?
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 16th April 2009, 08:21 AM   #25
chris661's Avatar
Made a XO using a stereo volume control (there's 2 resistors which determine the XO point, so I thought it would be better to make it variable, to find the best sounding XO frequency, then make a permanent version
Using it with this: http://www.amazon.co.uk/Sony-CMT-HX5.../dp/B000OVTUKQ
dual 4" drivers - reasonable volume levels, but amp not up to the 2x75W output it claims
but I listened before i bought etc, and the sound (despite what they say) is pretty good...
so - XO around 60Hz (speakers start falling off around there), and all is well
*gets calculator* so... my system's total price is
£162 - because i got the stereo for £120.
Old 16th April 2009, 08:20 PM   #26
chris661's Avatar
checked - 2nd order active crossover (variable, ofc)
more pics (and better quality) attached
Added CD to give a sense of scale...
Old 16th April 2009, 08:21 PM   #27
chris661's Avatar
Picture of the bottom.
Only used screws for this as I plan to add more bracing, sealed with foam gasket.
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
Charcoal "Supreem" hi-density foam "enclosure" IG81 Multi-Way 0 23rd April 2009 01:34 PM
What Does Fostex "Rated Input" and "Music Power" mark02131 Full Range 3 2nd January 2007 08:31 PM
Some final pics of "Stacks" revisited and "Askew" with stand Andy G Multi-Way 2 3rd February 2005 06:07 AM
Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? Ignite Multi-Way 3 18th November 2001 08:42 AM
Page generated in 0.10166 seconds (74.09% PHP - 25.91% MySQL) with 11 queries
