Black Widow 4ohm Help PLSS Newbie
Old 14th March 2009, 05:59 PM   #1
djjungle7895 is offline djjungle7895  United Kingdom
Smile Black Widow 4ohm Help PLSS Newbie
Hi all.
Great site very helpfull.
Heres My Problem.........
I have a pair of HK LP15 Bass Bins 300WRMS 600WPROG (8 OHM) 1 x 15inch driver in each, the drivers are now a little worn and not in the best condition.
I have aquired 2 nearly new 15inch Peavey Black Widow drivers these are rated at 4 Ohm each 350w RMS.
Would I be able to take the old HK drivers strait out and put in the black widows? and bin off the HK's.
Will they work fine with the internal crossover? in the HK Enclosures.
Will it make any diff using 4 OHM driver with the HK internal crossover that usualy does 8 Ohm?
Do you think it will sound any good?
ANY HELP VERY GREATFULL.......
The bass bins run purely off there own amp as in 1 bass bin to each channel the amp is a peavey 2x400w (or 2x600w@4ohms) (cs800 amp)
so my thinkin 4ohm drivers coupled with an amp that runs better at 4 ohms............
My top full range cabs run off a diffrent amp all together.
Thanks Again
Old 14th March 2009, 06:33 PM   #2
BTW they are used for Genral and dance sorta music And they are the black widow 15inch 4 OHMs
Thanks Again
Old 14th March 2009, 11:24 PM   #3
fotios is offline fotios  Greece
fotios's Avatar
Hi
If your HK bass bins include passive x-overs to give Hi outputs for satelittes and to cut high frequency part from bass drivers... and because the original HK bass drivers are 8, then if you connect 4 drivers in x-over, its cut-off frequency should be doubled... e.g. if was 200Hz with 8 load, with 4 load will become 400Hz. If you haven't audition problem with this, then there is not any significant electronic problem except this, your CS800 will be run most hot and maybe you have occasional thermal shut-down .
Fotios
Black Widow 4ohm Help PLSS NewbieHide this!Advertise here!
Black Widow info here... Russellc Analogue Source 5 5th November 2008 09:29 PM
NEED HELP on my Kenwood KD-500 and the Infinity Black Widow Tone Arm EJCUSA1 Analogue Source 3 22nd May 2004 07:21 PM
Kenwood KD-500 and the Black Widow NEED HELP EJCUSA1 Analogue Source 4 21st May 2004 06:09 PM
Infinity Black Widow mavz Analogue Source 7 13th February 2004 02:31 AM
Black Widow tonearm setup FrankW Analogue Source 3 13th January 2004 11:33 PM
