Simple subwoofer cross-over - diyAudio
Old 20th April 2003, 08:26 PM   #1
Matttcattt's Avatar
Default Simple subwoofer cross-over
i want a simple circuit to take the two outputs from my power amplifier (60w max), add them (or whatever you want to call it) and give me an output for a subwoofer.
thanks in advance for any help.
If it aint broke, don't fix it. If it is broke, fix it.
If you can't fix it, take it apart and see how it "worked".
Old 20th April 2003, 08:39 PM   #2
audioPT is offline audioPT  Portugal
Check
Rod's audio pages
http://sound.westhost.com/project84.htm
http://sound.westhost.com/project48.htm
http://sound.westhost.com/project28.htm
Pedro Martins
Old 21st April 2003, 09:01 AM   #3
Matttcattt's Avatar
there a bit complicated arnt they? i just want to add the outputs. i dont want any controls.
Old 21st April 2003, 06:35 PM   #4
Well,
In that case, and if you want a summing signal, just add 3 resistors and other amplifier.
at least 100k in each output of the main amplifier, join this 2 with another of 22k and then to ground.
you get the summing signal between the 2 extremes of the 22k resistor.
now, with this, you'll put into the subwoofer all the audio bandwidth. this signal is applyed to a third amplifier and...
some sound will get out of the sub.
more simple tan this, is impossible...
You can also put in parallel with the 22k resistor a 470nF cap to make a low pass filter.
I'd like to make a remark here:
This is the worst way to do this, but I'm answering to your question.
Another way is to buy a dual coil subwoofer and make a good low pass filter.
Pedro Martins
Old 23rd April 2003, 08:56 PM   #5
Matttcattt's Avatar
Originally posted by audioPT
Well,
Pedro Martins
like this?
Old 23rd April 2003, 09:34 PM   #6
Send a message via AIM to zx3chris
Default just made this ...
built this about 2 days ago and works perfectly. -3db is 70hz for subwoofer bass. i used 741s just as testing but better op amps should be chosen. the 3.9ohm load represents the speaker.
-chris
Old 27th April 2003, 09:05 PM   #7
Matttcattt's Avatar
like this?
Old 28th April 2003, 07:38 PM   #8
Hi Matttcattt
Just do like yhis:
(Beware that this isn't the best way)
To get better results, go active!
Pedro Martins
Old 28th April 2003, 09:45 PM   #9
Matttcattt's Avatar
thanks, where can i find a simple low pass filter as well? what would a suitable value for the low pass filter be? 100Hz?
Old 30th April 2003, 02:44 PM   #10
Matttcattt's Avatar
Hi Matttcattt
Just do like yhis:
Pedro Martins
is the 1uf capacitor the low pass filter or do i add a 470nf as well? or do i use a 470nf one instead of the 1uf?
Simple subwoofer/pre-out question theholmboy Subwoofers 14 11th January 2007 01:10 AM
Building Subwoofer Cross Overs? Dominick22 Subwoofers 15 22nd September 2006 08:15 PM
Simple Amp for active subwoofer Spiro007 Solid State 19 26th November 2004 04:01 PM
subwoofer+box wit a cross over project pinkfairy Car Audio 2 9th September 2004 09:36 PM
Copyright 1999-2017 diyAudio
