I'm afraid a quick search didn't yield an answer,
I'm wondering why plate amps don't include servo control options for subs ? I know some drivers have a separate coil to allow cone movement to be measured and fed-back to the amp etc. but in principle can't you measure the back e.m.f of the primary voice coil without any special windings and therefore achieve servo control on any driver ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#2 |
Do a patent search on acebass. Acebass is exactly servo, without the sensing coil. (aka, servo is an improvement over acebass)
a quick search came up with: STAHL - 'Acebass' Synthesis of Loudspeaker Mechanical Parameters by Electrical Means |
#3 |
perfect, thank you !
#4 |
http://www.audioxpress.com/bksprods/products/kw-6.htm
SB and audioXpress has had numerous articles on servos. Some also use a piezo transducer to obtain the voltage for the feedback loop. |
| DC servo in DAC | galouche | Digital Source | 5 | 2nd August 2007 09:33 PM |
| DC servo | uli | Chip Amps | 20 | 3rd December 2004 11:40 AM |
| DC servo in Amp | blu_line | Solid State | 10 | 26th November 2004 03:42 PM |
| To servo or not to Servo.. | ReSiStAnCe | Chip Amps | 10 | 7th February 2004 01:06 AM |
| Page generated in 0.07582 seconds (69.62% PHP - 30.38% MySQL) with 10 queries |
