Old 7th March 2009, 03:05 PM   #1
ataul is offline ataul  Bangladesh
Default What types of sub woofer sounds good
What types of sub woofer sounds good and easy to build.
Old 7th March 2009, 04:30 PM   #2
That's easy for me to answer and I have been quite certain of the answer since CDs came on the scene. Only a horn can blow enough air through a room to make good bass at realistic levels.
I also believe my opinion is probably distorted by "anthropomorphic" notions (rather than acoustic notions).
A 15 inch driver in a horn moves gallons of air with ease. Funny how carefully the wonks fret about peak amp power without spending a second wondering how much air a wee 10 inch driver could possibly move relative to a large bass side-drum (I heard Tan Dun conduct his spectacular piece, The Map, two nights ago with the Toronto Sym Orch... wow).
Pity they are the most complex constructions. Sad that SpeakerLab, great kit suppliers, died. I still miss 'em.
Nasty footnote: never seen any blind testing of it let alone been part of one, but I've always had a visceral dislike for resonant boxes like bass-reflex and derivatives. Again, maybe just ignorant gut feel, but I've never "felt" the system resonance of sealed boxes and other minor tuning found in enclosures was objectionable. I suppose you could have a well-damped port that kept resonances in check in tuned enclosures.
Dennesen ESL tweets, Dayton-Wright ESL (110-3200Hz), Klipschorn mixed-bass woofer w/param. EQ plus 1954 AR-1W or giant OB
HiFi construction since 1956
Old 7th March 2009, 04:33 PM   #3
Bigun is offline Bigun  Canada
Bigun's Avatar
It turns out that several different kinds all sound good, but people have different preferences so there isn't a simple answer.
Often it depends what you want it for e.g.
Home Theatre - lots of big rumbling bass ? (usually means not as good for hi-end music)
Car - some obvious limitations in terms of size ?
Music - looking for accurate low distortion but maybe not ground destroying power ?
Do you need a built-in amplifier (often called a Plate Amp) or will you buy an external amplifier ?
Easiest to build is probably to find a kit that you can buy, a box and driver. Otherwise, I'd go so far as to say the easiest is a simple sealed box with a single driver in it. A box with a port (often a tube installed inside the box to a hole in the side of the box) isn't much more difficult and offers some benefits and disadvantages.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 7th March 2009, 04:51 PM   #4
mikje is offline mikje  United States
Soakin' up the Sound!
mikje's Avatar
ataul,
If you're looking for one for music, this one might do
http://www.rjbaudio.com/Cerberus/cerberus.html
If not, Parts Express has a couple of plans that might work.
Mike
Marantz PM8003 amp, HRT Music Streamer II DAC, Squeezebox Touch, DIY Krystals
Old 7th March 2009, 04:55 PM   #5
Default Depends on what type of main speaker you have
My experience is (and it is limited) that if you go with a ported design, you can get very high output levels with great bass, until you reach the lower limit, when they QUIT. Also, ported designs have a tendency to have humps in their response curve which some people like. A properly designed port will give good results, but they also have overshoot on notes, so they have a slower sounding attack and release.
I have planar speakers which are very "fast" which a ported sub doesn't match well to. For this I ended up with an NHT dual 10 sealed box that, altough a huge power hog, is very fast and tight and has a smooth response all the way to the bottom. It mates well with my planars. The bass doesn't sound as loud, but to my ears it is more realistic....
Keep in mind, that the surface area of your driver is positively related to output and negatively related to speed. I feel the ideal driver side for speed is 10".
Old 9th March 2009, 10:15 PM   #6
badman is offline badman  United States
Custom Title
badman's Avatar
Default Re: Depends on what type of main speaker you have
Wow, you're a generalizations machine!
"Fast" bass is a function of inductance and driver bandwidth, not driver size. Smaller drivers tend to have less Le and more top end extension, but this is not a hard and fast rule.
Also, inductance varies with excursion (some motors keep it pretty constant, though) , so the driver 'speed' will change when it's pumping. Best to have a very large surface area moving gently, than a small one moving violently, in my experience.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
Old 9th March 2009, 10:19 PM   #7
MaVo is offline MaVo  Germany
fast bass? Its just a myth, grown on bad room acoustics and wrong eq and crossover settings.
Old 9th March 2009, 10:22 PM   #8
Speakerholic
Cal Weldon's Avatar
OK, let's not get too sidetracked here.
ataul,
Perhaps you could let us know a little more like your room size, volume requirements, what you are listening to etc. To ask a question like this, you will get too many answers to make sense of them.
Originally posted by mikje
ataul,
That's a 6.5" woofer. Don't get me wrong, a pair of them, each with it's own plate amp in my 100 ft2 bedroom works fine but...
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 10th March 2009, 07:22 AM   #9
dangus is offline dangus  Canada
Sealed box subwoofers have a lower order roll-off, which possibly means their transient response is better or something, from what I vaguely remember of circuit theory. They're also more tolerant of variations in woofer parameters.
In support, I'll submit the NHT SW3 which is/was a sealed box sub using the NHT1259 12". Several magazine reviews of subwoofers called it the most musical, but it'll rattle walls very well too. A lot of DIYers have and continue to build subs using that driver after it was made available to the general public.
Old 10th March 2009, 03:17 PM   #10
HK26147 is offline HK26147  United States
Sounds good is subjective ( and subject to all manners of never ending debate ).
Easy to build include - a closed box.
A lot of different ways to move air at LF, with different pluses and minuses. ( cost, size, complexity, etc, etc )
B&W DM110 - Woofer sounds nasty, help MikeHunt79 Multi-Way 3 2nd May 2008 05:56 PM
Sounds good, i like it, you may appreciate too. destroyer X Class D 95 22nd February 2005 09:09 PM
(Eton woofer problem) Speakers almost done, but bass sounds boomy Jimmy154 Multi-Way 47 13th August 2004 11:06 PM
Who determines what sounds good? Theli Multi-Way 68 9th February 2004 05:01 AM
24/96 and 24/192 is no good. MP3 sounds better! peranders Digital Source 92 30th July 2002 09:30 AM
Page generated in 0.11188 seconds (82.69% PHP - 17.31% MySQL) with 10 queries
