I've perused the Planet10 website and found the plans for a sealed, vented and ML-TL box for this driver. The ML-TL is almost 4' tall but I've seen another design which is shorter and used as a stand/base that utilizes two SDX7's in a push-push and side firing. It seemed like I've seen a few pictures of this sub over the months but now I can only find one. Has the plan been finalized? Is this design just a folded ML-TL?
#2 | |
Plans for that have to be asked for... but that design didn't work out as intended. It is a TL but stuffed to the point where it might as well be sealed. The box is too small. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
When I searched for SDX7 I did find where you were pleased with a 14litre sealed box. I just bought a single used one from the Market Place and will make a sealed box for it until I get a pair or two pairs.
How did the ML-TL design on your site work with the two drivers in push-push? |
#4 | |
dave
#5 |
What would you say is your favorite box to date for the SDX7 either single or bipole? How much amplifier power does each driver need? Size is not a problem, I'm a bachelor.
#6 |
Speakerholic
Would Shadow be a contender for the dual driver type? You could always plunk a mid and tweeter on the front.
#7 | |
dave
#8 | |
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#9 |
These will support a pair of Aiko's with the FE108Enabled drivers I got from Dave. Also a pair of Bose901's but don't tell nobody, I can't take the heat.
I can't honestly tell you what I'm looking for since all of this DIYAudio is so superior to what I've owned over the years. I always assumed it better to go with bigger drivers for bass but seeing how much the SDX7 is liked on this site, I've changed my mind. What does "WRT" stand for by the way? |
#10 | |
Speakerholic
WRT: with regards to eff: efficiency, but he really means sensitivity ![]() BW: bandwidth |
| 3 way with DX25, FR125S & SDX7 | sfreak | Multi-Way | 26 | 17th November 2011 10:28 PM |
| FR125S/SDX7 2-way | Timn8ter | Multi-Way | 41 | 11th June 2009 04:23 PM |
| CCS Kit options | eeyore | Tubes / Valves | 19 | 18th April 2009 04:29 PM |
| Mark Audio Alpair 5/CSS SDX7 DIY | Chris74 | Swap Meet | 4 | 17th February 2009 03:44 PM |
| wtb: CSS SDX7's | kappa546 | Swap Meet | 0 | 13th January 2009 09:13 AM |
| Page generated in 0.10646 seconds (77.62% PHP - 22.38% MySQL) with 11 queries |
