Old 1st March 2009, 09:40 PM   #1
tinitus is online now tinitus  Europe
Default 6th order bandpass question
Hi
I am wondering why low end rolloff on a 6th order bandpass is always rated as equal to driver Fs, or close to, which would make it very attractive with use of pro woofers
Is that fore real ?
To me it doesnt look much different from ordinary BR, but it obviously is
Does anyone have any explanation to this ?
Old 1st March 2009, 11:10 PM   #2
GM is offline GM  United States
GM's Avatar
Oh really?! News to me.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 2nd March 2009, 12:56 AM   #3
Thanks GM, I was hoping you would turn up
As I expected, its an error with that low rolloff
May be that its the frequency where its 12db down, or something like that
I dont know the standards fore bandpass, apart from having steep rolloff
Nope, it says 3db down at 32hz
driver Fs of 30hz, 0.25Qts, Vas 300 (imaginary woofer)
Rear chamber 174liter, two ports tuned to 30hz, each with ø100mm x 260mm long
Front chamber 60liter, one port tuned to 60hz, ø100mm x 170mm long
Old 2nd March 2009, 02:03 AM   #4
GM
Ahh, yes I see now...its just the tuning...stupid me
Old 2nd March 2009, 01:57 PM   #5
I may be naughty, but in my files I call this a "Tapped Ported Bandpass"
Question is whether there could be phasing issues between the ports ?
Old 2nd March 2009, 02:28 PM   #6
GM's Avatar
Agreed.
There will be if not properly tuned, same as a TP, TH.
GM
Old 2nd March 2009, 02:48 PM   #7
Ok, thanks
1. Will it be better this way ?
2. Or maybe bottom port should face downwards ?
3. Or will port phasing always be a risk/issue ?
4. Any suggestions what to do best ?
Old 2nd March 2009, 03:19 PM   #8
GM's Avatar
Don't know, they all seem same-same to me, so better to use an 8th order Karlson IMO if not a TP or TH or even a B@$3 WC if a vented rear chamber is used, with bulk Vs output for a given BW being the final arbiter.
GM
Old 2nd March 2009, 03:33 PM   #9
I know what a TH means
But the other WC, TP, BW or 8th order Carlson...sorry, dont know what that means
Old 2nd March 2009, 03:45 PM   #10
GM's Avatar
Bose Wave Cannon, tapped pipe, band-width, Karlson K-15 box alignment, an 8th order band-pass (four tuned resonant cavities).
GM
6th order bandpass Chris8sirhC Subwoofers 1 13th September 2008 07:09 PM
4th Order Bandpass Help berserker Subwoofers 9 19th January 2007 03:56 PM
4th order bandpass with PR tade Subwoofers 2 14th November 2005 01:08 PM
A question about 6th order bandpass design simon5 Subwoofers 5 5th December 2004 09:29 PM
6th-order Bandpass BAM Subwoofers 1 24th September 2001 05:51 PM
Page generated in 0.10235 seconds (80.38% PHP - 19.62% MySQL) with 11 queries
