Left - SubWoofer - Right Crossover - diyAudio
Old 17th April 2003, 09:20 PM   #1
Ford_V6 is offline Ford_V6  Romania
Default Left - SubWoofer - Right Crossover
Hy.
I want to make this kind of crossover to connect a 12" sub and two sattelites (8" mid + TW) to the power amp.
All the speakers are 8 ohm.
Now. . . i would like the crossover to cut at 150 Hz. The sub must play what's under 150 Hz and the sattelites the rest.
What values would you recommend me for C and L in this case.
I have 64uF and 1.7 mH. Are these values right ?
Do you know a better method to connect these speakers to a stereo power amp ?
Thanks,
Old 17th April 2003, 11:18 PM   #2
moamps is offline moamps  Croatia
your schematic can not work; sub play only diference between L and R channel, Left MTW is out of phase.
Old 18th April 2003, 06:14 AM   #3
Ok, thanks
Now how can i still connect a subwoofer and two sattelites to a stereo amp ?
A link, a schematic something ?
Old 18th April 2003, 09:04 AM   #4
pinkmouse's Avatar
Hi Ford
I have never seen a passive crossover that will sum the bass from two channels .
Your options are to buy a dual voice coil sub driver, and use a circuit similar to the one below, (this crosses over 1st order 100Hz, and I would not recommend going higher for a single sub), or go active and build a PLLXO from Planet 10's site and get another amp.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 18th April 2003, 12:28 PM   #5
audioPT is offline audioPT  Portugal
Simple:
Just do this;
1- in one chanel, insert a inverter before the input of the amplifier, using a simple opamp.
2- in the output if this channel, invert the polarity of the speaker.
Here you have the 'magic of this':
connect the sub to the + outputs of both channels.
You can still use the crossovers you design.
Any comments from moamps and pinkmouse?
This is a simple configuration of car audio amplifiers
Pedro Martins
Old 18th April 2003, 01:47 PM   #6
Hi, Pedro
Idea is OK. But, if somebody has knowledge to install inverter between preamp and amp, I think that better idea is implementation active sub.
In passive combination anyway you have big work to do; from huge choke for sub and rest of world to adjustment levels between. Simplest way is active.IMHO
Old 18th April 2003, 02:34 PM   #7
pinkmouse's Avatar
Seconded
Old 18th April 2003, 02:47 PM   #8
Of course active is the best way.
But I'm only thinking in low cost for Ford_V6
The implementation of an opamp it's very easy, right?
If cost isn't important, go active!
Pedro Martins
Old 20th April 2003, 12:29 PM   #9
Ok
Thanks, i will go active.
I was thinking in using a bridge configuration of the TDA7294 for the power stage.
Or is better a discrete amp ?
What do you think ?
Old 20th April 2003, 02:13 PM   #10
Go!
The better way to don't waste time is using bridged TDA's
Pedro Martins
subwoofer with no crossover MikeN Subwoofers 9 2nd December 2008 07:17 PM
Subwoofer crossover / subwoofer module design derMichi Subwoofers 4 20th April 2006 10:31 AM
Subwoofer Crossover Dj BASS AMP Solid State 7 30th December 2005 04:46 PM
My subwoofer Crossover & LT merlinx76 Chip Amps 15 12th February 2005 08:08 PM
Subwoofer Crossover amoeba86 Subwoofers 1 17th May 2003 01:53 AM
Copyright 1999-2017 diyAudio
