Greetings,
Does anyone know if I can use this amp as a subwoofer amp: Full Range Plate Amp. I really dont need the high frequency output but it maybe useful should the need arise. Thanks. |
#2 |
Speakerholic
You can add a dummy load on the high end for the time being but unless you need an active speaker amp, why are you looking at this instead of a regular plate amp? The XO point on that amp is 3K. Not what you want to send a subwoofer. You would need extra coils and caps and that would get expensive.
#3 |
Hi Cal,
Reason is it's a lot cheaper and i can use it as stereo. I will have to look for other alternative. Thanks. |
| Plate Current VS Plate Voltage Graphs | Captn Dave | Tubes / Valves | 2 | 13th February 2009 08:57 PM |
| ECC83 - Long Plate vs Short Plate | poynton | Tubes / Valves | 16 | 17th February 2008 07:42 AM |
| 2a3, single plate-double plate? | tenderland | Tubes / Valves | 5 | 30th October 2005 09:03 AM |
| Subwoofer Plate Amplifier Base Plate supplier? | jwells777 | Parts | 1 | 11th May 2003 07:40 AM |
| Page generated in 0.07194 seconds (70.11% PHP - 29.89% MySQL) with 10 queries |
