Old 23rd February 2009, 11:56 PM   #1
Bigun is offline Bigun  Canada
Bigun's Avatar
Default Push-Push or Push-Pull
Now that it's no longer a question of using two drivers I should probably start a new thread with this.
Based on advice so far I have ended up with a simple box, birch play and braced internally. Two drivers in push-push and an integrated amp to avoid microphonics (although I'm not quite convinced on this front for solid state). There's no semblance of a golden ratio in this design of course.
But it seems a bit boring not to build a push-pull instead, given that it would be a bit more challenging and less a look-alike for an off-the-shelf sub. I recognize that the benefits should be more noticeable with less linear drivers and with larger excursions - but I may not be able to appreciate the difference. You see, I've never had a sub and I will have nothing to compare it with if I build it since I don't really want to get into doing too many experiments. I've also heard that there is the risk of unwanted noises from the vented magnet. So common sense says build a push-push and yet my hands want to build a push-pull.
It's a question that no doubt has been asked before, but I thought perhaps not with these specific drivers ???
Here's the push-push version
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 23rd February 2009, 11:58 PM   #2
Bigun's Avatar
And the Push-Pull version.
A little loss of box volume, easy to compensate for with an extra cm all round.
Old 24th February 2009, 01:14 AM   #3
JLH is offline JLH  United States
JLH's Avatar
Push-pull 100%
Old 24th February 2009, 01:50 AM   #4
GM is offline GM  United States
GM's Avatar
Default Re: Push-Push or Push-Pull
Well, at least you have some common sense which is more than can be said of many folks, but DIY audio is mostly about satisfying oneself, so why are we having this conversation?
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 25th February 2009, 12:02 AM   #5
MarkR is offline MarkR  United States
Build both
Two enclosures shouldn't take long or cost allot. Try them out see which one yours ears like better and if they can't tell them apart pick with your eyes.
Old 25th February 2009, 01:02 AM   #6
tinitus is online now tinitus  Europe
Both ways ought to be possible in the same box
Old 25th February 2009, 01:20 AM   #7
Bigun's Avatar
It could be done, although it turns out easier if I wanted to try them both inverted rather than neither of them inverted.
I had a question about speaker grill/covers. For subs, the excursions can be large, so does this imply that the grill has to be spaced off from the cone surround by essentially xmax - which can be quite large ?
Old 25th February 2009, 01:46 AM   #8
I dont think so
The surround doesnt move outwards to the same degree as the cone Xmax
But you should be able to carefully move out the cone, and see how much change it makes on the surround
Old 25th February 2009, 04:45 PM   #9
Speakerholic
Cal Weldon's Avatar
The surround will move 1/2 what the one way Xmax is (not P-P)
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 25th February 2009, 08:17 PM   #10
Bigun's Avatar
My shipment arrived from Creative Sound Solutions today. First time I've seen or held a sub-woofer driver. They are quite different from the little Fostex full-range drivers. But I can say that I am very impressed with the out-of-box quality of the TRIO8s. They are nicely finished and look to me to be well thought out and made with good quality materials. Decision made. The Push-Pull will allow me to view the front and back of this lovely driver for years to come !
modify parallel push-pull EL84 to single push-pull chungtat Tubes / Valves 12 3rd November 2005 11:25 PM
help tuning push-push ApexJr super 8 woofer planet10 Subwoofers 22 28th September 2005 04:00 AM
Photos - My first T-Line Push-Push Subwoofer :) Xmax BR Subwoofers 6 23rd June 2005 08:17 PM
push-pull-push-push Chris8sirhC Multi-Way 14 27th February 2004 05:42 PM
Double push-pull versus single push-pull jraraujo Tubes / Valves 19 19th October 2002 12:23 AM
Page generated in 0.10140 seconds (82.21% PHP - 17.79% MySQL) with 11 queries
