Old 5th March 2009, 01:34 AM   #51
frugal-phile(tm)
planet10's Avatar
Originally posted by Bigun
The rods will be in tension and could have a piano-wire oscillation in which the box would be a wonderful sound board.
That is what the afore-mentioned heat-shrink is intended to combat.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 5th March 2009, 03:41 AM   #52
MJL21193's Avatar
Right now I have only a couple of little clamps which aren't long enough to get across the side of the cube. There are two sides of the box gluing in the basement, two bags of cement on top and my tool box hanging off some string on one corner to close a gap and some rubber mats on the floor in case the string breaks.
Yes, I've been there too. The funkier it looks, the better it clamps - bucket o' screws, paint cans, 18" woofer... it's all good.
Old 5th March 2009, 08:12 PM   #53
AKN is online now AKN  Sweden
Enjoy good sound
AKN's Avatar
When I mentioned rods earlier I did think of solid rods thick enouth to be threaded in the ends. Thus allowing use of ordinary machine screws securing the driver units.
Thoughts of this idea?
/ Anders
Old 6th March 2009, 02:06 AM   #54
Bigun is offline Bigun  Canada
Bigun's Avatar
MJL - looks great, I think we're going to need a dedicated thread for everyone to show off their jury-rigged gluing operations !
4fun/Dave - I've gone with the no.10 threaded rod and I'll put something on them to damp vibrations. I don't have heat-shrink but something else will be found. I don't fancy starting with plain rod and cutting my own threads - don't own the tools and it's not worth it for this one project.
Moondog - definitely need some bracing in the corners between sides. I just happen to have some very nice quality thin-ply (packaging from an Italian football table). Thin means quick and easy to shape and drill holes in. Thin doesn't mean it's not strong. The floor joists in my house are made from engineered wooden I-beams with very thin verticals. The trick is that they are deep - a beam's stiffness depends very much upon it's depth. So I've cut up the thin ply and glued it all over the inside of the box, edge on, to create a very stiff structure with little penalty in weight or volume. A bang on the side makes a nice satisfying 'thunk'. Not sure if this photo explains it any better...
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 6th March 2009, 03:43 AM   #55
Moondog55's Avatar
Photo explains every thing very well, what damping if any are you using inside the cabinet??
That tapped rod idea did sound interesting, easy to do if you have a lathe
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 6th March 2009, 03:19 PM   #56
Bigun's Avatar
I have some man-made poly-bat left over from the Moon-Onkens that I bought locally. It's white, fairly stiff, doesn't shed fibres and is in a large sheet about 3/4" thick. Since I have no other use for it I planned to cut it up and use it in the sub. I don't really need much in the way of 'stuffing' to increase apparent box volume so it's more in the way of damping.
I'm still thinking about the BASH500 plate amp. It has some internal heat sinks so I have decided not to put it into it's own box within the enclosure. This allows some air movement around those heatsinks. But, it's a Class-D amp and they produce EMI. So I'm now thinking about adding some conducting mesh and foil. I have some local expertise where I work and will seek some advice on that today.
Old 9th March 2009, 01:24 AM   #57
Bigun's Avatar
end of this discussion about driver quantity and time to show results
continued at: Altair Sub (2x TRIO8's)
modify parallel push-pull EL84 to single push-pull chungtat Tubes / Valves 12 3rd November 2005 11:25 PM
help tuning push-push ApexJr super 8 woofer planet10 Subwoofers 22 28th September 2005 04:00 AM
Photos - My first T-Line Push-Push Subwoofer :) Xmax BR Subwoofers 6 23rd June 2005 08:17 PM
push-pull-push-push Chris8sirhC Multi-Way 14 27th February 2004 05:42 PM
Double push-pull versus single push-pull jraraujo Tubes / Valves 19 19th October 2002 12:23 AM
Page generated in 0.09457 seconds (76.89% PHP - 23.11% MySQL) with 11 queries
