Old 16th February 2009, 02:05 AM   #1
Default How important are dimensions?
If I get the volume correct on a sub, how important is it to get the actual dimensions in the right ratio? I have heard it is not as important on a sub....but this design is actually more of a "supplemental woofer" to go with my monitors (weak-ish bottom end). It will be tuned well into the directional range (probably ~ 140 hz). I'm looking more at a tall square box rather than 1-2-3 ratio. The front baffle will be a bit wider than I would like because of shape constraints imposed by a small living room.
Old 16th February 2009, 03:44 PM   #2
GM is offline GM  United States
GM's Avatar
Until one dimension reaches 1/4 WL long in the speaker's BW to affect vent tuning, not much beyond the fact that as you move away from a golden or acoustic ratio in a large cab it typically requires more damping material to quell any eigenmodes (standing waves) that might reflect back through the driver. For sealed it's just a matter of damping to 'taste', i.e. removing any 'hollow' sound.
Of far more importance is placing the sub ideally within a 1/4 WL of the XO's -12 dB point to each main, but unless multiple subs are used it severely limits the mains' spread and room location to between them, so up to ~1 WL is often used, though with a 140 XO point it may sound a bit disconnected on some music if this far away.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Important Paper... mikeks Solid State 5 8th February 2005 06:45 PM
Important!!! Clarkcr The Lounge 4 15th September 2004 03:34 AM
where is short wiring in an amp important/ not important ? sandro600 Solid State 5 4th April 2004 03:10 AM
Bl important? pkgum Multi-Way 2 1st January 2002 04:07 PM
Page generated in 0.05752 seconds (73.76% PHP - 26.24% MySQL) with 10 queries
