Old 15th February 2009, 06:06 AM   #1
Default Sub firing direction plan
Ok I have 2 JL12w6v2s that I am building sealed boxes for, material is already cut. I wanted them to be down firing. After researching a bit the only real issue I would have is the lack of spacing and the carpet they sit on. So to get around that I was thinking of taking the sonotube design ideas and use that. Make a piece out of mdf 1.5" thick spaced 4" down from the box. Any reason why I can't do this and try it out?
Old 15th February 2009, 09:40 AM   #2
I;ve read somewhere that the minimum space btwwen the sub and floor should be 3", So you should be fine.
One concern I have with down firing is that ,that JL sub have heavy cone which might disalign the motor by a few mm in the long run.
Old 15th February 2009, 09:54 PM   #3
Yea I read up a little about sag. They have been sitting in the boxes face up for about 3 years now. I'm only using these for now since I have them. I plan to eventually change them out with something else in the future.
Old 19th April 2009, 06:13 PM   #4
Click the image to open in full size. Click the image to open in full size.
Going to go put the second one together now.
Old 19th April 2009, 06:54 PM   #5
chris661's Avatar
the space between the floor and the box should be equal, or greater than, the area of the speaker cone divided by the length of the egdes of the box around the driver.
This way the air sitting between the box and the floor will only move as far as the driver moves - shortening the distance will make the box (if it was sealed) like a 4th order bandpass thing, without tuning.
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 20th April 2009, 01:12 AM   #6
GM is offline GM  United States
GM's Avatar
Close, you ideally need to factor in peak excursion........ FWIW, since Xsus usually isn't known, I use 1.5x Xmax as a close enough approximation except for XBL^2 motors. My limited experience with these is to slot load them if there's enough power on tap to drive them beyond Xmax.
Anyway, 4" is plenty for two of these drivers and based on published specs there's no problem with sag either.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Front firing vs down firing sub? alex_g Subwoofers 32 22nd June 2010 12:34 PM
Down firing vs side firing? Tee-Bruce Subwoofers 36 26th August 2009 06:32 AM
Woofer: side firing pair vs front firing? tcpip Multi-Way 13 9th September 2005 02:13 PM
Sub Amp..in need of direction sickss Solid State 2 16th February 2005 04:01 PM
Page generated in 0.07615 seconds (76.09% PHP - 23.91% MySQL) with 10 queries
