More then one driver in Horn Response
Old 4th February 2009, 10:03 AM   #1
jamikl is offline jamikl  Australia
Default More then one driver in Horn Response
After you have entered the parameters for a single driver in Horn response and then select for example two drivers in parallel does the programme change the parameters itself before calculating the horn or do you have to make the appropriate changes to the parameters yourself. I have always understood that it was changed within the programme but not shown as changed parameters in the parameter fields. Is my understanding incorrect.
Thanks for a wonderful program Mr. McBean.
jamikl
Old 4th February 2009, 11:09 AM   #2
MaVo is offline MaVo  Germany
hornresp does it automatically, internally.
Old 4th February 2009, 11:44 PM   #3
Thanks for that MaVo.
jamikl
More then one driver in Horn ResponseHide this!Advertise here!
junkiest PC that'll run horn response? pjanda1 Full Range 9 13th July 2009 09:00 AM
Single Driver Horn Base Port from Frugal Horn EmergencyDpt Swap Meet 0 26th October 2008 01:24 AM
Front horn, HF response. jnb Multi-Way 6 22nd February 2008 02:50 PM
how to go from horn response to a folded bass horn design? paulspencer Subwoofers 8 4th November 2005 10:44 PM
Comments on bass horn sim in horn response paulspencer Subwoofers 38 1st November 2005 08:34 PM
