#31 | |
Regards Charles |
#32 | ||
Speakerholic
Nope, I think i need a smaller truck |
#33 |
Hi Cal
Have you thinked to use a band-pass cabinet for 4 X 15" woofers? You know probably the tremendous UDH of Peavey, which are obsolette of course now. I had 4 original such type subwoofers and i made also 4 clones. For rental of course, not to meet my new neighbours! I can confirm you that UDH can touch frequencies down to 35Hz with enough SPL to sake-down your liver. It is heavy, but it is smallest in size compared with your Altec or JBL style horns. A usuall truck like a 4 X4 Ford or Chevy or Dodge, can contains 4 UDH. The advantage (if your wife agree of course I have the complette plans to build one if you wish. In the photo (from the web, not mine) you can see a UDH. Specs: 1) Response: 35 - 250Hz 2) Z configurable: 2, 4, 8 Ohms 3) Power handling: 1400W continuous 4) SPL: 105dB/1W/1m 5) Transducers: 4 X BW1505-8 6) Weight: 280 lbs 7) Dimensions: 41"H X 30,5"D X 30"W Regs Fotios |
#34 |
Speakerholic
Hi Fotios,
Thank you for that. Yes I would be most interested in having a look at the plans. Can you post them here or send them via email? Thank you. |
#35 | |
I will contact tomorrow again. Fotios |
#36 |
Speakerholic
Thanks, looking forward to it.
#37 |
Hi Cal
I ask your forgiveness for my delayed reply, which caused from that i had only hand made drawings (during 1998 there was not serious PCs and CAD softwares in reasonable prices as well ------ Anyway, if you find interesting the project, i leave in you the decision of oppening a seperate thread for this powerfull subwoofer of Peavey. NOTE!!!: Because in Europe we use currently the metric system, all dimensions are expressed in mm, as well the plywood that i used, was of 20mm thick, insted the 3/4" thick (19,05 mm) of the original speaker. For any detail, as usuall i am available. PDF drawings, are also available, please ask me. In a couple of days i will have ready and the 3D model. ADVICE!!!: For easiness, the construction it is better to done from inside to outside ![]() ![]() ![]() ![]() ![]() Regs Fotios |
#38 |
Speakerholic
Thank you Fotios, those look very reasonable and not to hard to bang together. Do not worry about the delay, we had more snow today so building is still on the horizon.
Cheers. |
#39 |
Hey Cal, I feel sorry for your wife. Your definitely horny, and if your package is too big, she must be suffering
Couldn't you just get a trailer?! Peace, Dave |
#40 |
Speakerholic
I am still pondering. I would like to keep the big boxes but...
We'll see. |
| I found a very versatile DMM since mine went bad | mcmahon48 | Everything Else | 18 | 5th March 2009 11:59 PM |
| Anybody want a job? Mine?? | Jack Crow | Everything Else | 0 | 5th April 2006 12:01 PM |
| I just fired mine up....... | reever | Chip Amps | 2 | 2nd May 2005 11:15 PM |
| Does no one have any car audio? - here's mine | maxw | Car Audio | 23 | 13th November 2004 08:02 AM |
| Page generated in 0.11879 seconds (84.92% PHP - 15.08% MySQL) with 11 queries |
