subwoofer box
It may indeed work out OK....Heres' the Thiele Smalls.
fs=35Hz
Qes=.47
Qms=5.36
Qts=.43
Xmax=6.2mm
EBP=75
Sens. 92Db
...40-2K Hz.
____________________Quick, who can crunch the numbers the fastest. The EBP puts it in the ported camp, but that Mechanical at 5.36??
________________________________________________Rick.....
ye i know its not what i want.. i want a digitals designs 12 :D.. which i will eventualy get.. btu since i go thsi lieing around n i love building stuff i thought id put it in a car. um so what box should i make that be best.. like size n port size etc.. been trying to use winisd.. but when i put in t&s specs it says cant convert floating point?? n also if i cna get it working what frequencies should i be looking at getiing the loudest etc? only seventeen and only getting into all this spl stuff last few days.. cheers!
Disabled Account
Joined 2007
50 litre box, port = 10cm inside diameter, 22cm long. About 110db at 50Hz with 80 watts of power.
