Help Improve Parts Express Plate Amp - Page 3 - diyAudio
Old 17th July 2010, 09:25 PM   #21
Congrats! I noticed an improvement myself, basically did the same thing as you, replaced the 6800uf caps with 10,000uf.
Another thing you can try is to remove the 30Hz boost, or reduce it slightly, if you find that the amp runs out of steam or 'clips' when pushed too hard. I would rather have no boost but cleaner bass at 30Hz with more overall headroom, than the 30Hz 6dB boost, which basically sucks 4X the power at 30Hz and quickly clips the amp...
After i did that, the plate amp was much cleaner sounding. That was probably the difference you heard between the plate amp and your power amp driving the sub.
Gd luck!!
FS: Parts Express 250watt plate amp jin5 Swap Meet 3 14th March 2008 04:36 AM
FS ... Parts express 250 watt plate amp ... jhammer221 Swap Meet 3 24th March 2006 01:34 PM
parts express ! onis_uk Multi-Way 9 7th August 2004 01:56 AM
Copyright 1999-2017 diyAudio
