Old 27th January 2009, 02:20 PM   #1
Village Plank's Avatar
Default Running a passive sub with main speakers off an integrated amp!
A quick question, Is it possible to run a passive subwoofer inline with main speakers off an integrated amp?
Wiring options:
1, Connect to left or right channel?
2, connect left channel to + and right channel to -?
3, connect to sub second speaker output channel?
4 Do any of the above and kill the amp or speakers?
The amp in question is the Kenwood KA-5020 looped with 12 band EQ.
Old 27th January 2009, 05:20 PM   #2
sreten is online now sreten  United Kingdom
The subwoofer must be matched to the main speakers and include
the necessary crossover which filters the sub and may or may not
filter bass to the main speakers.
All in all a subwoofer plate amplifier is more flexible.
/sreten.
Old 27th January 2009, 07:45 PM   #3
/sreten.
Any high frequency coming from the amp will be filtered by the sub x-over before it hits the sub coil!
Old 27th January 2009, 11:29 PM   #4
Speakerholic
Cal Weldon's Avatar
The caps and coils needed for a sub XO are about the same price as buying a plate amp. The plate amp also allows you to match the level and cut off point of the main speakers. Passive subs XO's are a thing of the past.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 28th January 2009, 01:56 AM   #5
Default sub woff
Hi there: I tried this several years ago, and I was never happy with the result. I removed the passive crossover, bought an electronic crossover, which provides a low hz amp output and a mid/hi hz amp output, allowing biamping a two way system, where most of the music is played by the "main speakers". THe old sub speaker/enclosure still serves in the biamped system. The integrated amp provides the signal to the low hz speaker, with level adjust to my taste. The master gain on a preamp serves the whole system, I normally run the system flat and seldom use tone controls. I've noted subtle bass passages in some classical cd's which were missing previously. as well as room filling bass in other compositions (classical) and enjoy modern jazz and classic jazz.
Old 28th January 2009, 03:10 AM   #6
Depending on the impedance of the sub, your option of running subs as the "B" speakers on your integrated amp is probably the best, though it is not without compromises. You will still want to eliminate the high frequencies from the subs and you may want to limit the lows to the main speakers. This requires crossovers.
As stated above, passive crossovers make no sense for subwoofers. One could easily spend more on a pair of quality inductors and capacitors than a decent plate amplifier costs. Budget caps and coils may get the job done for less, but will only provide a 6 dB/octave crossover which really won't do much to protect the main speakers from excessive excursion (or cross the high frequencies from the subs). Higher order crossovers = more parts, which = more money.
Years ago, I used active automotive crossovers and additional receivers to integrate subs into my systems. This worked, but was not all that cheap, all things considered. I use plate amps now. Many of these amps will accept speaker-level inputs, making integration with your system quite easy.
Among the other great stuff on his site, Jack Hidley sells 115 Watt Foster subwoofer amps for $50 plus shipping. The site indicates he will ship internationally, though costs may be prohibitive.
http://home.comcast.net/~jhidley/
Passive preamp before an integrated (?) amp 454Casull Solid State 4 15th April 2009 07:08 AM
Using subwoofer with large main speakers Godzilla Subwoofers 26 11th May 2008 11:31 PM
Installing a "main out" in an integrated amp? driving Solid State 0 11th December 2004 11:07 PM
Picture of my main speakers markp Multi-Way 6 19th June 2004 01:42 AM
Main Stereo Speakers geobill Multi-Way 5 20th March 2002 05:20 AM
Page generated in 0.11482 seconds (76.94% PHP - 23.06% MySQL) with 10 queries
