Old 26th January 2009, 10:08 PM   #1
yan6 is offline yan6  Canada
Default Adding Subwoofer to FE206's
Hi there I have built a set of Solo206's with FE206's in them and I am looking to add a sub. This project is kinda two-fold. I am looking for something small to add to my Solo206' and to add to my fathers angular spirals which have very poor bass volume as discussed here
I was thinking about the 30 or 38 tapped horns as seen in the lower part of this page. My question is whether or not the bass output from these 6 1/2"ers will be enough to keep up with my Solo206'. I would like to wire these in two cabinets in parallel, but I'm not sure how mixing impedance will work ie: the Tangbang is 4ohm while the Fostex is 8ohm.
Ryan
Old 27th January 2009, 12:44 AM   #2
didn't you build the spiral due to space problems? that sub will be huge... btw i think once you have a sub than the 206 would sound better sealed than in the spiral...
did you tried the bsc on the spiral already? i think i won't, and rather change enclosure to my AN, anyway on good recordings i was getting bass from them... everything else was the big problem... take a look on the thread zeppelin in the Audio Nirvana
someone suggested good enclosures also for the 206 when paired to a sub...
Old 27th January 2009, 12:59 AM   #3
My father chose the spiral due to space & WAF factor. I have another set of spirals for my sister, which space isnt an issue. But the 38Hz model is fairly small in packaging. For myself (Solo206') I was looking for a little more bass support.
I havent tried the BSC yet. I just ordered the parts on Saturday.
Adding Subwoofer output to Sonic T-Amp HolyGhostFire20 Class D 4 23rd November 2011 07:33 PM
Adding Subwoofer output to Aikido preamp circuit dr._sleep Tubes / Valves 5 13th November 2007 04:18 PM
adding a crossover to an active subwoofer Saltuk Subwoofers 9 20th January 2006 03:37 PM
BSC for FE206 ML TL + SI t-amp paanta Full Range 10 16th October 2005 03:45 AM
adding mass to subwoofer to lower fs mikesimas Subwoofers 2 13th May 2002 08:15 AM
Page generated in 0.05775 seconds (78.67% PHP - 21.33% MySQL) with 10 queries
