I've built a small, approx 30litre, passive subwoofer. It uses 2 x 8inch drivers in isobaric configuration. It is ported by a single port 3inches in diameter and 10 inches in length. Both drive units have been heavily modified and have fs of 20hz. Just need some suggestions as to how I can alleviate the bass hump between 35hz-50hz (please see attachment) Thanks in advance |
#2 |
Without driver specs, it's hard to say, but a double hump is usually due to a high inductance (Le) combined with a too high a tuning.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#3 |
Thanks GM.
Sorry I couldn't provide driver specs, as the drivers are very heavily modified and are pretty old. Just general suggestions to get me started. Both of which are very good. Thanks |
#4 |
I could be caused by the room you are using it in.
Try moving it around the room, let it play in the room, find where bass sounds best in your room and put it there.
DIYaudio for President ! |
#5 |
Thanks Simon.
The measurements were taken in an anechoic chamber. |
#6 | |
Hi, Unless it is a seriously big and very expensive anechoic chamber the bass end will have errors. Vented tuning of the box is ~ 40Hz. If driver Qts is too high you will get a peak around/above the vent tuning frequency whatever you do. Only if the bass is dry and overdamped with the port sealed will vented work. In that case simply keep tuning the port lower and lower until any sign of a peak disappears, possibly go a little lower for better transient response / room matching. The above assumes normal design parameters. FWIW 30L / ~ 1 cuft is very large for isobaric 8" drivers and this suggests something is very amiss somewhere. |
#7 |
Thanks, Serenten.
I have the system tuned at 20Hz. I've tested manufactured active subwoofers in this Chamber and they have measured as per the manufacturer’s specs, no humps or bumps. I may try varying the inductor value to see if that will affect the overall response. |
#8 |
Ok, it seems removing the capacitor and leaving the inductor removes that hump. Not good, as plenty of midrange seepage!
However, there is still a slight dip between 25hz-40hz. Guess I will need to experiment with different drive units. I might decide to just go active! The subs do sound great, with great extension and solid upper bass. However, can be a bit overwhelming (Due to the hump) |
#9 | |
A 3" diameter port would need to be 40" long for a 30L box. These are WinISD numbers, not exactly accurate but ballpark. Your box is tuned to ~ 40Hz. |
#10 |
I measured the system tuning and the impedence dip centred at 20hz. Thanks |
| Converting a Passive Subwoofer to Active | noromamai | Subwoofers | 5 | 16th April 2007 07:29 AM |
| subwoofer crossover passive and active | yikchean | Subwoofers | 3 | 3rd December 2006 02:18 PM |
| Passive Crossover for Passive Subwoofer? | Toast_Master | Subwoofers | 23 | 30th April 2006 12:14 AM |
| Powering passive subwoofer? | NickZ | Subwoofers | 5 | 22nd December 2005 12:36 AM |
| Page generated in 0.09625 seconds (78.11% PHP - 21.89% MySQL) with 11 queries |
