Old 21st January 2009, 03:22 PM   #1
Default el pipe-o
Hi all,
I am just wondering whether anyone has done an el pipe-o or similar with the adire extremis...I have a couple kicking around that i'd like to use for a sub and am unsure which way to go...
thanks,
byron
Old 21st January 2009, 04:47 PM   #2
GM is offline GM  United States
GM's Avatar
No, but should work OK. Personally, I prefer to put low Vas drivers in a TQWT (reverse tapered) or better yet, a tapped TQWT now that we can sim them.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 1st February 2009, 11:19 PM   #3
nuconz is offline nuconz  United States
GM
ok, i'll bite - how is low Vas determined?
Old 2nd February 2009, 12:40 AM   #4
Moondog55's Avatar
I'll bite too, for a different reason, what exactly is a tapped QWTL and how does it differ from a tapped horn??
So far none of my in stock drivers seems to be suitable for a tapped horn so I have not paid much attention to that series of threads.
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 2nd February 2009, 04:47 PM   #5
GM's Avatar
If a T/S max flat alignment requires a vent that's large/long enough to have vent harmonics low enough in frequency (i.e. high amplitude/Q peak) to comb filter with the main's BW and meet the 5% mach vent peak speed limit (~56.5 ft/s (17.22 m/s)) at whatever the predicted power required, then Vas is low, which means many (most?) current drivers fall into this category to minimize box size at the expense of acoustic efficiency. Or you can just arbitrarily use the old rule-of-thumb of ~13.78"/35 cm at rated amp power.
GM
Old 2nd February 2009, 04:51 PM   #6
GM's Avatar
It's a reverse tapered TL (TQWT) except tapped whereas the typical posted TH is a positive tapered tapped TL (horn).
Recently, me and bjorn have suggested tapped TQWTs in some apps and he's since designed/built a couple, so do a search of him to find the various posts.
GM
Old, old, PVC pipe design... Ronmeister Multi-Way 6 5th June 2009 11:55 PM
El Pipe-O's as Art? Scott Stansbury Pass Labs 2 14th October 2008 06:42 AM
El-Pipe-O (El-Pipe-Mino) ??? JDeV Multi-Way 21 26th October 2005 09:00 AM
El-Pipe-O ??? JDeV Multi-Way 0 6th October 2003 09:30 PM
El Pipe-O Nelson Pass Multi-Way 7 9th January 2003 06:30 AM
Page generated in 0.08159 seconds (74.09% PHP - 25.91% MySQL) with 10 queries
