can a speaker operate if the voice coil interacts with only one pole of the magnet?
#2 |
Wouldn't that mean that the cone only moves in one direction ? I mean both north and south poles are required for both positive and negative wave cycles (and polarity changes based on the AC wave cycle or how far along the wave cycle is)
So then I take it that the waveform wouldn't be reproduced. But I'm sure someone more knowledgeable will tear my words down. Regards, |
#3 |
No a magnet always have two poles.So the the voicecoil will interact with both.
#4 |
you only need 1 pole for the voice coil to move.
#5 |
you answered your own question.
Audio is AC and does the change of attraction/repulsion in the voice coil. |
#6 |
just wanted to double check before i drop $200 on NEO bars to make a sub.
#7 | |
But you may be planning to have the coil only near one pole; the other pole far away - which in effect give you a really HUMONGOUS air gap, compared to conventional driver construction. Result = low magnetic flux = poor effieciency & low power handling. |
#8 |
There are a variety of transducers that use only 1 pole of a bar magnet such as the ribbon tweeter on this page:
http://www.lautsprechershop.de/hifi/aka_hoch_en.htm http://www.visaton.com/bilder/sonsti...utsprecher.gif Audio Magazine had a construction article ( 70's ) orienting neo bars magnets in V's on both sides of the membrane. Perhaps an unconventional design is in mind? |
| Jensen 4-poles capacitors for sale | hc167 | Swap Meet | 3 | 19th September 2008 07:32 PM |
| Transfer function. Poles not where expected | Raka | Multi-Way | 35 | 29th July 2008 01:20 PM |
| correct # of poles source selector? | h_a | Solid State | 2 | 6th February 2007 09:28 AM |
| Bypasses still needed w/ Jensen 4 Poles? | tonyptony | Parts | 1 | 10th April 2006 03:54 PM |
| Bypasses still needed w/ Jensen 4 Poles? | tonyptony | Power Supplies | 0 | 9th April 2006 07:41 PM |
| Page generated in 0.10218 seconds (78.57% PHP - 21.43% MySQL) with 10 queries |
