Icebear gave a Karlson-dipole box sub a whirl a few years back - it had two drivers and rear slot aperture was inverted - besides looking different and potentially exhibiting a cavity peak, could the approach be useful?
#2 |
A sudden flash of inspiration. Wouldn't it look kool to have a 2 driver dipole karlson box.
If you don't like the look of the woofer motor, you could hide it behind the skinny portion. IF you do, you put it in the open portion. Or you could hide them both behind grille cloth.... enjoy.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#3 |
for the phase of the two drivers? I agree I like the look.
moray james |
#4 |
I was thinking one mounted with cone facing forward and one with cone facing back, wired so they move the same direction. Instead of Ripoles, freddi could call these Kipoles
BTW, that's my first Sketchup model ever, done in ~15minutes. Would have taken less time, but I am used to AutoCAD.
#5 |
So the drivers are mounted such that their magnets are both inside of the cabinet and from the front or back side of the cabinet if you look inbetween the tapers all you will see is cone, is that correct?
Are the drivers in phase with each other? Meaning that a positive impulse causes both cones to move out of the cabinet at the same time? That being the case we have a Bipole configuration. Or are the drivers wired so that as one cone moves into the cabinet the other moves out of the cabinet. Sorry but I always get myself confused about this sort of thing. I think that I have a disconnect between what I read/think and what I visualize which probably has something to do with my dyslexia. Thanks for taking the time to make your thoughts clear to me
moray james |
#6 |
Here in Norway we have an loudspeaker-manufacturer wich makes a sort of dipole like that:
Its sounds nice with all the benefits of a dipole construction, but the midrange/tweeter suffer from the positioning inside the wraping. |
#7 | |
I don't think the couplers would do much other than perhaps mass-load the diaphragms a bit. The concept looks kinda kool, and I don't think the couplers will hurt anything in a subwoofer application.
#8 |
Some thoughts about that double Karlson H frame (Kipole) Ron E showed above:
1. Looking at the large opening at the top of the frame it should behave like a conventional H frame with its quarter wavelength resonance. Looking at the almost non-existent opening at the bottom it should behave like a closed box with a half wavelength resonance inside. So I would expect a somewhat "smeared" resonance peak, mainly at quarter wavelength but broadened to higher frequencies. You could get a similar "smearing" of the resonance by rotating the driver baffle 45° in a conventional H frame. Whether horizontal or vertical 45° doesn´t matter. 2. The Karlson slot aperture closes the H frame opening to some degree. This is what a Ripole does too. So you can expect some mass loading of the driver (probably resulting in a lower Fs) and a pronounced quarter wavelength resonance peak (which will be attenuated by the slot aperture as discussed in 1. Since we are talking about subwoofer frequencies, the special exponential(?) aperture of the slot doesn´t matter at all.
www.dipolplus.de |
#9 |
Anyone try one yet ?
I am contemplating a dual 18" dipole , perhaps a w-frame , but this Karlson loaded dipole (Karlsonpole I think I read it called on the FR Driver forum) is very interesting. Any thoughts , links, etc. how it would compare to a W frame ? I read that Ice Bear had something like this, but the pics posted were no longer viewable. Thanks.....................Blake
Keep it simple |
#10 |
Keep it simple |
| WTB - Transylvania "The Tube" + Karlson 12 | freddi | Swap Meet | 0 | 1st August 2008 12:41 AM |
| "Karlsonology" (Karlson enclosures/technique) what's happenin' ? | freddi | Multi-Way | 45 | 29th January 2008 10:06 PM |
| Karlson "projectors" and HF waveguide tubes | freddi | Multi-Way | 3 | 9th December 2007 10:47 PM |
| Karlson - "equal amounts of energy"- what did he mean? | freddi | Multi-Way | 8 | 25th May 2007 07:44 PM |
| Helper tweeter lens via ~Karlson idea "THE KUP" | freddi | Full Range | 0 | 25th November 2006 07:54 PM |
| Page generated in 0.13986 seconds (72.92% PHP - 27.08% MySQL) with 11 queries |
