how to model tapped horns?
Old 10th January 2009, 04:31 PM   #1
weikertball is offline weikertball  Germany
Send a message via AIM to weikertball Send a message via MSN to weikertball
Default how to model tapped horns?
I can't find any information on how to model a tapped horn. The tapped horn option in hornresp doesn't show up no matter what I do. Any help would be nice.
Old 10th January 2009, 06:21 PM   #2
MaVo is offline MaVo  Germany
make sure the 6 lower input field are filled with 0 each. then press ctrl+d and dial in the tapped horn, press ok, fill s1-s4 and the length fields (the upper three lines where the actual horn sizes are put in) with some values, press ctrl+h and adjust its parameters in the wizard.
Old 11th January 2009, 09:43 PM   #3
Rademakers is offline Rademakers  Netherlands
http://www.diyaudio.com/wiki/index.p...=Hornresp+Help
Scroll about 70% down the page.
Wkr Johan
Impossibilities we do immediatly, miracles take slightly longer.
how to model tapped horns?Hide this!Advertise here!
jbell's set of four tapped horns davygrvy Subwoofers 481 5th November 2016 09:02 AM
Dampening in Tapped Horns?? atilsley Subwoofers 25 20th June 2009 08:24 AM
Copyright ©1999-2017 diyAudio
