#121 |
Have you tried modelling a longer version of the horn? I bet that this will get you closer to your personal experiences than commentaries from us... With the data I have given you, you should be able to simulate a RT that matches the anecdotal history of bass performance. (dry 30 Hz). I should build it myself, but have other things to do now.
I sehs there is no stronger breastplate, than the heart that is undainted. |
#122 | ||||||||
Late, but 2 cent of thoughts about what’s been said about RT-2: Any speaker can use closeness to sidewalls to furniture’s etcetera, but should be measured in an environment that doesn’t depend on user unique influenced speaker placement where proximity to objects and distances are unknown. This dependency must be IMO ruled out, i.e. like done for the original FR curve that is correctly showing the horn performance when being measured in Pi environment. Here my translation of some text taken from the Swedish link I earlier referred to : ///…Schematisk bild av hornet och hur man räknar fram detta ur en befintlig låda. Varje förändring av tvärsnittetets kontinuerliga ökning av arean har mätts. Det framgår av tvärstrecken i schemat. RT-2 slutar med myningen nedtil under lådan. Lådan har ben som gör att utymmet blir ordntligt tilltaget. Det har också placerats en triangelformad låda undertill. Myningen och den triangelformade lådan påstås skapa ett sista hornsegment. Vid simuleringar med detta sista segment stämmer inte frekvenskurvan alls med de mätningar som också gjorts på hornet. Om man inte tar med denna sista bit då stämmer mätningar överens med simuleringar bättre. Därför har den sista biten utelämnats…/// Translated to: Quote:
Post#84 Quote:
post#102 Quote:
post#120 Quote:
Post#121 Quote:
If you really want to squeeze out more extension from this design: start to find a driver that uses the enclosure dimensioning optimal (GM posted a good hint) and experiment with different damping of the internal volumes of the closed box compartments. b 1(1) |
#123 |
Unfortunately, I don't have any means of making any measurements, so all I can do is to listen and compare with my old sub..
Regarding extending the horn physically.. In the articles published in this sort of horn in 1973 (then with 10" driver), there was an illustration showing the horn flanked by two furniture sections standing on legs at the same height as that of the horn floor. This was said to extend the low end response noticeably. Would be interesting to try.. |
#124 |
Well, we did suggest several times to convert it into a "tapped-horn"
http://www.danleysoundlabs.com/tappe...?MODEL=TH%2028 |
#125 |
was just in a playfull moode
#126 |
Well, I'm keeping the horn, and since, after reconsidering driver selection philosophy, it turned out to be great sounding. (been listening through some records now..), the next step is to fit the driver properly and give the thing a nice veneered finish.
And since it was eventually sucessfull, I'll post some construction pic's for the benefit of any other that might wish to give it a go! |
#127 | ||||||
I have no personal experience other than simulating and reading other people's experience. I base my opinion partly on the original article about the RT-3 and RT-2. Quote:
It MAY work out very differently. I have had good experience with other horns of my own design and boosting.
| Interesting TL Result | Mudge | Multi-Way | 13 | 24th March 2004 05:00 PM |
| Page generated in 0.13990 seconds (81.36% PHP - 18.64% MySQL) with 11 queries |
