Hello guys,
I would like some help with my subwoofer design. I want to build and enclosure for selenium's 18SW1P. The design attached here uses numbers that i got from selenium's website. According to selenium's calculation, if the sub is in a box with 3 ducts of 13cm and a vb of 300 i should get a F3 of 30hz and a Fb of 34hz. I am looking for a sub that can go at very low frequencies but still put out a clear bass. So i would like some help double checking this calculations, and maybe even changing the type the box for something that would better suit my needs. I made the design using Sketchup, and it was my very first attempt using a 3D modelling program, so bear with me. If you need any more information to help me plz ask! |
#2 |
I tried to attache the spec sheet but it was a bit too big.
So here is a bit more information about the Selenium's 18SW1P SPECIFICATIONS Nominal diamet er . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 460 (18) mm ( i n ) Nominal impedance. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8 ohms Mi ni mum impedance @ 106 Hz. . . . . . . . . . . . . . . . . . . . . . . 7.0 ohms Power handling Musical program . . . . . . . . . . . . . . . . . . . . . . . . . . . 1, 600 watts AES . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 800 watts Sensi t i vi t y ( 1W/ 1m) averaged f r o m 80 t o 250 Hz . . . . . . . . . 97 dB S P L Power compr essi on @ 0 dB ( nom. power) . . . . . . . . . . . . . . 3.3 dB Power compr essi on @ - 3 dB ( nom. power)/2 . . . . . . . . . . . . 2.8 dB Power compr essi on @ - 10 dB ( nom. power)/ 10. . . . . . . . . . 0.7 dB Frequency respons e @ -10 dB . . . . . . . . . . . . . . . . 30 t o 2, 500 Hz THIELE-SMALL PARAMETERS Fs . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 29 Hz Vas . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 395 (13. 344) l (ft ) Qt s. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.34 Qes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.35 Qms. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10. 93 no (half space) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.03 % Sd . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.1194 (185. 07) m (in ) Vd ( S d x Xmax) . . . . . . . . . . . . . . . . . . . . . . . . . 1,134.3 ( 69. 22) c m ( i n ) Xmax (max. excursi on (peak) with 1 0% di st or t i on) . . . 9. 3 ( 0. 37) mm( i n ) Xlim (max. excursi on (peak) bef or e physi cal damage) 25. 0 ( 0. 98) mm( i n ) ADDITIONAL PARAMETERS bL . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20.7 Tmβ Flux density . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.90 T Voice coil diameter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 100 (4) mm ( i n ) Voice coil winding length . . . . . . . . . . . . . . . . . . . . 39.7 ( 130. 3) m (ft) Wi re t emperature coeffi ci ent of resi stance ( ) . . . . . 0.00372 1/ °Cα 2 5 Maxi mum voice coi l operating t emper at ur e. . . . . . . . 275 ( 527) ° C ( ° F) vc (max. voi ce coi l operating t emp. / max. power) . . 0.34 ( 0. 66) °C/ W( °F/ W)θ Hvc ( voi ce coi l wi ndi ng dept h) . . . . . . . . . . . . . . . . . 32.0 ( 1. 26) mm ( i n ) Hag ( a i r gap hei ght ) . . . . . . . . . . . . . . . . . . . . . . . . . 13.5 ( 0. 53) mm ( i n ) Re . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.5 ohms Mms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 147. 3 (0.325) g (lb) Cms. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 198. 6 m/ Nµ Rms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.5 k g/s NON-LINEAR PARAMETERS Le @ Fs (voi ce c o i l inductance @ Fs) . . . . . . . . . . . . . . 10. 694 mH Le @ 1 kHz ( voi ce coil i nduct ance @ 1 kHz) . . . . . . . . . . 2. 152 mH Le @ 20 kHz ( voi ce coil i nduct ance @ 20 kHz) . . . . . . . . 0. 508 mH Red @ Fs . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.77 ohms Red @ 1 kHz . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8. 88 ohms Red @ 20 kHz . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 80. 23 ohms Krm . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14. 375 ohms Kxm. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 145. 290 mH Erm . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0. 735 Exm. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0. 518 ADDITIONAL INFORMATION Magnet material . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Barium ferrite Magnet weight . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3,440 (120) g ( oz ) Magnet diameter x dept h . . . . . . . . . . . . . . 220 x 24 (8.66 x 0. 95) mm ( i n) Magnetic assembly weight . . . . . . . . . . . . . . . . . . 11,200 (24. 69) g ( l b) Frame material . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Aluminum Frame finish . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Black epoxy Magnet i c assembl y steel f i ni sh . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Zinc-plated Voice coil materi al . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Flat CCAW Voice coil former materi al . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Fiber glass Cone mat eri al . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Non pressed long fiber pulp Volume displaced b y woofer . . . . . . . . . . . . . . . . . . . . 8.6 (0.304) l (ft) Net weight. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14, 180 (31. 26) g (lb) Gross weight . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15, 400 (33. 95) g (lb) Carton dimensions ( W x D x H) . . . . . . 48 x 48 x 24 (18.9x18.9x9.5) cm (in) |
#3 | |
Speakerholic
The Selenium is not a subwoofer as such. It is a sub by PA standards but not hi-fi. You will get clear clean bass but it won't go low as you can see by your calculations. |
#4 |
From his post in the amps section, I figured he would be using it for PA work, DJ ing, that sort of thing. From the specs, the driver pretty much looks like the PV Lowrider. 30 Hz is pretty low for PA - most of the pro's try to save their backs and live with a lot higher f3.
#5 | ||
I am not sure if i should know this by now… but is there a particular reason to stay away from very low frequencies in the PA system? |
#6 |
Speakerholic
I use quite a few Selenium pieces and find they are well built and quite rugged. It seems only the tweeters get noticed but the woofers are no slouch. Good bang for the buck.
Stay away from low frequencies as they really suck up the power. By sacrificing the low end you get more volume. Duct placement is not a huge thing but don't put rear ports right behind the driver. |
#7 | |||
If it is not good, i wouldn’t mind hearing that i got it all wrong and should start it all from scratch. |
#8 | |||
Speakerholic
#9 |
It is a "floor rumbler" compared to a lot of the stuff that's out there. Should be capable of 30 Hz in an EBS-type alignment. The catch is the power handling will drop to about 600W, and that means if you want a lot of output down that low you need more than one. That's where the 'wall of woofers' comes in.
Most of the pro's will state (quite adamantly) that anything below 40 or 50 Hz is a waste. Not in my experience - I usually boost the half octave below 40 to get that shuddering, throbbing bass that breaks down your defenses. Just going from a 40Hz capable system down to 30 with any type of dance music feels like being let out of jail. But threre isn't a whole lot below 30 - the dBx 120A subharmonic synth will only put out tones down to 26 Hz. If you high pass there you won't miss it. Getting below that with any type of PA requires either multiple esoteric drivers with a quarter million watts behind them or a truck full of lab horns. |
#10 | |
That makes Eminence cheaper here. But they are a bit behind the curve on drivers in the 600 watt and up class, and Selenium has stomped them on compression drivers since the 90's. |
| Amp for Selenium's 18SW1P | asnn | Solid State | 5 | 8th January 2009 10:49 PM |
| few questions on my enclosure project | frontier | Subwoofers | 3 | 2nd May 2008 10:39 PM |
| Enclosure suggestion/questions | santiu | Tubes / Valves | 12 | 29th December 2005 06:20 PM |
| Questions about building a sub enclosure | soundNERD | Subwoofers | 2 | 24th October 2005 01:24 AM |
| Enclosure Idea, but a few questions. | Milzie | Multi-Way | 2 | 4th December 2002 05:56 PM |
| Page generated in 0.14964 seconds (85.12% PHP - 14.88% MySQL) with 11 queries |
