Hi all,
I have a pair of Infinity car subwoofers (12 inch). And comparin the parameters of those and the Eminence Lab 12, I find that only a few parameters are different. The problem with the Infinity subs is that they seem to need a lot of power to be driven well though they are rated at 90dB. One thing is that the inductance of the car sub is much higher. Could this be a factor in the car sub needing higher power? The force factor of both does not vary by too much. Any thoughts would be appreciated. Below are the parameters of both. Thanks and regards, Vivek LAB12 SPECIFICATION Nominal Basket Diameter 12", 304.8mm Nominal Impedance* 6 ohms Power Rating Watts 400W Music Program 800W Resonance 22Hz Usable Frequency Range 25Hz-125Hz Sensitivity*** 89.2 Magnet Weight 160 oz. Gap Height 0.375", 9.53mm Voice Coil Diameter 2.5", 63.5mm THIELE & SMALL PARAMETERS Resonant Frequency (fs) 22Hz DC Resistance (Re) 4.29 Coil Inductance (Le) 1.48mH Mechanical Q (Qms) 13.32 Electromagnetic Q (Qes) 0.39 Total Q (Qts) 0.38 Compliance Equivalent Volume (Vas) 125.2 liters / 4.4 cu.ft. Peak Diaphragm Displacement Volume (Vd) 659cc Mechanical Compliance of Suspension (Cms) 0.35mm/N Product (BL) 15.0 T-M Diaphram Mass inc. Airload (Mms) 146 grams Efficiency Bandwidth Product (EBP) 56 Maximum Linear Excursion (Xmax) 13.0mm Surface Area of Cone (Sd) 506.7 cm2 Maximum Mechanical Limit (Xlim) 22mm Infinity Reference 1230W: SENSITIVITY (2.83 V @ 1 M): 90 dB POWER HANDLING: 300 W R M S 1200 WPEAK FREQUENCY RESPONSE: 23 ~ 400 HZ NOMINAL IMPEDANCE: 4 OHMS VOICE-COIL DIAMETER: 2.0" (50.0 MM) VOICE COIL DC RESISTANCE: REVC (OHMS) . . . . . . 3.40 VOICE COIL INDUCTANCE @ 1 KHZ: LEVC (MH) . . . . . . . 2.54 DRIVER RADIATING AREA: SD (IN2) . . . . . . . . 82.48 SD (M2) . . . . . . . 532.00 MOTOR FORCE FACTOR: BL (TM) . . . . . . . . 14.63 COMPLIANCE VOLUME: VAS (FT3) . . . . . . . . 2.78 VAS (LITERS) . . . . . 78.50 SUSPENSION COMPLIANCE: CMS (ìM/N) . . . . 195.40 MOVING MASS, AIR LOAD: MMS (GRAMS). . . . 174.21 MOVING MASS, DIAPHRAGM: MMD (GRAMS) . . . 167.15 FREE-AIR RESONANCE: FS (HZ) . . . . . . . . 27.27 MECHANICAL Q: QMS . . . . . . . . . . . 6.14 ELECTRICAL Q: QES . . . . . . . . . . . . 0.47 TOTAL Q: QTS . . . . . . . . . . . . 0.44 MAGNETIC-GAP HEIGHT: HAG (IN) . . . . . . . . 32.50 HAG (MM) . . . . . . . . 8.00 VOICE-COIL HEIGHT: HVC (IN) . . . . . . . . . 1.27 HVC (MM) . . . . . . . 32.50 MAXIMUM EXCURSION: XMAX (IN) . . . . . . . . 0.49 XMAX (MM) . . . . . . 12.25
Thank God for DIY audio. |
#2 |
Vivek, it appears that a much smaller cab would be required for the Infinity driver as compared with the LabSub driver, if we are talking about a BR cab.
Sam |
#3 |
I have used a 62L box. And I do not understand what BR means. Could you please explain? Vivek
#4 |
BR is Bass Reflex.
Sam |
#5 |
BR = bass reflex ( I think ) a ported box
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING" |
#6 |
Okay. Sorry it did not occur to me. My boxes are sealed.
Any more thoughts/opinions? Vivek
| Another cap comparison | Conrad Hoffman | Parts | 57 | 29th May 2007 10:38 PM |
| TX9 Comparison | dirtyk777 | Subwoofers | 0 | 15th March 2007 03:57 AM |
| DIY Comparison | marcus555dc | Subwoofers | 0 | 21st February 2006 12:05 AM |
| AB comparison | Raka | Chip Amps | 124 | 27th June 2003 09:06 PM |
| Page generated in 0.08727 seconds (76.52% PHP - 23.48% MySQL) with 10 queries |
