Best small musical sub? - diyAudio
Old 6th January 2009, 05:09 AM   #1
Send a message via AIM to Spasticteapot
Default Best small musical sub?
I'm looking for a small sub to be used with two RS150/Neo3PDR sealed-box speakers in a sub-sat arrangement. I really only need from 30hz to 80hz or so. I've never heard a ported sub I really liked, so I was hoping to try something different.
Options include:
-Peerless XLS 10 with passive radiator. They don't play deep enough in a sealed box, but with the matching PR, you can use a very small box anyway. You can get one of these lightly used for $100 or so, but the PR seems to be found only at Madisound for $85. Ouch!
-JL 8W7 (it measures quite well, apparently) in a small sealed box. Many drivers are ill-suited to small boxes - apparently, the compression and decompression of the air can cause odd-order harmonics - bu the 8W7 is made for it. It's a great sub....but look at the pricetag!
-Unknown subwoofer in a tall transmission line. While this sub would be big, if built tall enough it would take up very little floor space. Not going to be pleasant to look at, though.
Any other ideas?
Old 6th January 2009, 07:14 AM   #2
frugal-phile(tm)
planet10's Avatar
Default Re: Best small musical sub?
A PR is just a substitute for a port (with an additional resonance)
CSS SDX7 works well in a small sealed box.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 6th January 2009, 07:27 AM   #3
The SDX7s are not subwoofers. Even if I used two, I'd still blow the voice coils if I wanted an F3 of 30hz.
Old 6th January 2009, 07:51 AM   #4
frugal-phile(tm)
planet10's Avatar
Don't be so sure. I've measured flat to 25 in room with sealed SDX7 (with a touch of EQ) I typically use a pair.
Maybe i should ask how small is small?
dave
Old 6th January 2009, 10:45 AM   #5
Moondog55's Avatar
Will these do ??
shipping too much to OZ but maybe??
http://cgi.ebay.com.au/JL-AUDIO-SUBW...742.m153.l1262
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 6th January 2009, 12:44 PM   #6
Just an idea, my "invisible" TL sub
http://www.audioxpress.com/magsdirx/...nnesen2835.pdf
Bjorn
Old 6th January 2009, 01:04 PM   #7
Dr_EM is offline Dr_EM  United Kingdom
Dr_EM's Avatar
A Ripole might be worth consideration.
Old 6th January 2009, 02:42 PM   #8
http://www.linkwitzlab.com/Pluto/subwoofer.htm
would probably be where I was looking.
You could also look at the scanspeak 23W but its pricey and such a small driver playing so deep is going to run out of xmax pretty fast.
You could also look at the xls10 sealed with a Linkwitz transform
Old 6th January 2009, 04:07 PM   #9
Bjorn
Interesting, but I don't really have a place to put the flat part of the sub. I'd also like to use a higher-end driver, and I can't find a place that will let me download mathcad.
I would assume that the lack of direct radiation would be bad for high-frequency response?
Old 6th January 2009, 04:39 PM   #10
Brett's Avatar
Why do you want HF out of a sub? For 80Hz, side firing will be fine.
Musical Fidelity B1 amp - repair and small mod tuck1s Solid State 1 8th January 2013 08:57 AM
small-signal (small-power) fast switching complementary transistors Lola Luna Solid State 3 8th April 2010 07:51 PM
Small-signal (or small power) pentode that can handle 400V (or more)? GordonW Tubes / Valves 12 13th June 2008 02:07 AM
PC-speakers + small amp (key words: small, cheap) rho Multi-Way 8 18th May 2006 01:19 PM
small musical subwoofer? Dave Jones Subwoofers 8 20th September 2003 01:40 PM
Copyright 1999-2017 diyAudio
