On an AR P315HO speaker I have a few questions about the adjustment of the down converters.
-What input and output levels I should I aim for when adjusting RP1 and RP2? -What is the load impedance that the amp drives? (I don't have the speaker with me and want to connect a power resistor for testing) - is the 500 watt output a continuous level, ie. what maximum level should I not exceed. Hope you can help. Don Whyte |
#2 |
After some thought I figured I didn't need to consider the input and output levels. I connected a 5 ohm 50 watt power resistor and with an oscilloscope adjusted the down converters so the + and - rails tracked about 7 volts above the audio signal. Per Jack Hidley's suggestions. Thanks
The amp is rated to produce 500W rms but I didn't drive it anywhere near that. I am seeing about a volt of some ultrasonic noise at 67 KHz and about 800 Khz in the (-) down converter and it's feeding through into the output stage. It appears at the inputs to the comparator U4-B and looks like a subharmonic of the 135 Khz oscillator, and not properly filtered in the (-) down converter. But it might be partly be parasitic feedback from the output - I can't determine. The 800 Khz also appears in the (+) down converter but is filtered out before the output. In any case it's beyond the audio range. It would be quite a bit of work to check all the filtering components. Any ideas? |
| Regulator adjustment | Prune | Parts | 6 | 16th June 2010 03:53 AM |
| P315HO Subwoofer amp | Jimmy154 | Swap Meet | 2 | 29th June 2009 01:17 PM |
| BOZ bias adjustment help | rtate | Pass Labs | 16 | 11th July 2008 07:04 PM |
| p315ho amp and lambda 15 don't like eachother, now what? | Dejavous | Subwoofers | 4 | 23rd April 2008 02:45 AM |
| Adjustment of CDM 4/19 ,any help please! | zygibajt | Digital Source | 0 | 20th November 2004 10:18 AM |
| Page generated in 0.06587 seconds (71.54% PHP - 28.46% MySQL) with 10 queries |
